 Post subject: Barracuda 7200.11 1.5tb stuck
PostPosted: March 11th, 2017, 6:53
Hi to everyone, i have a broken seagate hdd which my phd thesis' files are inside. I appreciate if someone identifies what the problem is. When i plug it to power, the head moves forward and back several times (like 20 secs) and than it stops spinning. Thank in advance for every help.
 Post subject: Re: Barracuda 7200.11 1.5tb stuck
PostPosted: March 11th, 2017, 7:12
You already opened it ?? :shock:
Maybe your thesis is gone now...
ACELab partner
PostPosted: March 11th, 2017, 9:13
Assuming that you are screwed without the thesis, you should stop messing with your drive and contact a reputable data recovery lab.
PostPosted: March 13th, 2017, 10:16
ahhh, clicking 7200.11 opened by a user, what a beauty
PostPosted: March 15th, 2017, 9:02
Why is that? i didnt touch any part especially the magnetic spin. i opened it to show you the behaviour of the head, filmed it and closed. i appreciate any help
PostPosted: March 15th, 2017, 9:32
The problem is the dust particles. Harddisks should only be opened in cleanrooms with dust-free air.
PostPosted: March 15th, 2017, 12:02
In addition, when the lid is closed there is air pressure inside the drive allowing the heads to "float" on a cushion of air, thus not touching the platters.
PostPosted: March 15th, 2017, 12:56
So to make air pressure drive has air compressor inside, right?
2 TS
Your problem most likely in bad heads. I would recommend to go to pro.
Users browsing this forum: sixsweets and 80 guests
