 Post subject: ST1000DM010 P/N : 2EP102-300
PostPosted: March 15th, 2017, 15:12
Is dead and i change te PCb, same model but 2EP102-500
Terminal output is :
QNR Boot: Interface Reset Received.
Boot 0x40M
SpinUp
RECOV Servo Op=0100 Resp=0005[LBA=0x000044E8]N01010C20o0o0o0o0o0o0o0o0[LBA=0x000044E8]NO1111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01
RECOV Servo Op=0155 Resp=0005[LBA=0x0007DDB8]N01010C10o0o0o0o0o0o0o0o0[LBA=0x0007DDB8]NO1111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01
RECOV Servo Op=0055 Resp=0005[LBA=0x00006B6F]N01010C10o0o0o0o0o0o0o0o0[LBA=0x00006B6F]NO1111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01
RECOV Servo Op=0155 Resp=0005[LBA=0x0008043F]N01010C10o0o0o0o0o0o0o0o0[LBA=0x0008043F]NO1111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01
SimError - Remaining in BootFW
Perform a double download without a power cycle
The PCB is not compatible ? Os it look like need change heads?
Thank you in advance.
 Post subject: Re: ST1000DM010 P/N : 2EP102-300
PostPosted: March 15th, 2017, 16:13
It is necessary to transfer native ROM to a new PCB
PostPosted: March 15th, 2017, 16:27
PN is ok. Did you read the ROM? First, check SN.
Users browsing this forum: Google [Bot], smkubin and 62 guests
