 Post subject: pcb issue
PostPosted: June 13th, 2017, 2:37
when we connect only hdd pcb to terminal by rs232 to ttl converter we get the error as in attachment .Do any one have any solution ,I dont need any data just i want to know the problem.
New Text Document.txt [1.78 KiB]
Downloaded 549 times
 Post subject: Re: pcb issue
PostPosted: June 13th, 2017, 15:30
The solution is to screw the PCB onto the drive.
PostPosted: June 14th, 2017, 23:34
According to the suggestion will it work.
PostPosted: June 16th, 2017, 14:10
Spildit wrote:
:shock: :shock: :shock:
No comment ....
Haa Haa ,
Spildit Now You Know How Hard Its To Deal In India :D
PostPosted: June 16th, 2017, 18:44
Sadly, that kind of thing happens in other places too.
