 Post subject: ST500LM000 Unknown Device
PostPosted: May 23rd, 2017, 8:56
So I have this drive that won't show up in Windows at all, but using Parted Magic, it shows up correctly until I attempt mounting the partitions, or clone the drive.
Then it just shows up as Unknown Device in Parted Magic.
Is this something that can be fixed without a board replacement?
Thanks a lot in advance :D
 Post subject: Re: ST500LM000 Unknown Device
PostPosted: May 23rd, 2017, 17:21
Can you get a SMART report with CrystalDiskInfo?
PostPosted: May 24th, 2017, 4:28
Unfortunately not.
The drive seems to switch to unknown device from any kind of attempt at smartctl or other inquiries made to the drive.
Attempts to read table made both through terminal and GSmartControl.
PostPosted: May 24th, 2017, 6:10
Board replacement will not help, drive has diskware problem. This is SSHD, drive shows parameters taken from PCB FW. It has SA\heads problems. Not for usual users.
PostPosted: May 24th, 2017, 8:38
This series of drive is even tough for many professionals.
PostPosted: May 25th, 2017, 2:34
if data is important for you it's better to find DR specialist
http://www.hpwlab.com
PostPosted: May 25th, 2017, 2:39
What does it sound like?
Spinning normally?
Clicking?
Silent?
Quiet "buzz bzz bzz" noise and then silent?
PostPosted: May 25th, 2017, 12:59
Well,
I could handle any SSHD Months before PC3K latest update came out .But now this should be easy as the new update works with NAND drives in hybrid technology
Users browsing this forum: No registered users and 214 guests
