 Post subject: HDD Regenerator vs. HDAT vs. ???
PostPosted: May 31st, 2017, 20:16
What's the best freeware software for repairing hard drives that would otherwise be permanently broken?
 Post subject: Re: HDD Regenerator vs. HDAT vs. ???
PostPosted: May 31st, 2017, 20:41
If someone told you that hdregenerator could repair hard drives ...... they lied to you.
Never use this program against a disk with physical damage.
Almost never solve the problem but you can make some great paperweights ......
PostPosted: May 31st, 2017, 23:21
I've used it and have had some good results. I'm not asking for a comprehensive solution. I just want to know if it's a choice between throwing a hard drive in the trash or hooking it up to a software hoping that it gets fixed, what software should I try to use?
PostPosted: June 1st, 2017, 2:02
freeware software depend on problem hard disk problem is( bad sector - module problem- no detection - format problem - and slow work ) what you want .. all hard disk has etc etc etc software but --- you want free version and some kind repairing your hard disk use victoria(VCR) DEPEND on your case ....... :D :D :D :D :D :D
PostPosted: June 1st, 2017, 4:41
These threads might be worth a look:
http://www.hddoracle.com/viewtopic.php?t=2077
http://www.hddoracle.com/viewtopic.php?t=2068
You might also like to read various "selfscan" and "burn-in" threads by dilworks and Spildit at the HDD Oracle forum.
