Seagate F3 [ Is Serial Number In ROM ? ]
May 4th, 2015, 5:59
Hello ,
I have 4 Units of Seagate 7200.12 Series F3 With Me .The Following Are The Model Numbers ST3500418AS X 2,ST3500413AS X 1 And ST3160316AS .Do they have thier serial number in ROM .If yes whats the location .The ST3500418AS X 2 + ST3160316AS Have PCB Number 100535704 Rev C .
Re: Seagate F3 [ Is Serial Number In ROM ? ]
May 4th, 2015, 6:35
I believe the serial number is stored in the ROM's Controller Adaptive Parameters File (CAP).
May 4th, 2015, 6:59
Spildit wrote:Looks quite simple.
Dump your ROM with a firmware tool like PC3K, MRT, etc or with external programmer.
Open the dump with hex editor like HxD.
Search the ROM dump for the serial on the label.
Done.
Well,
I have All The 4 File .Will Upload It Soon .I could not see anything .I dumped it with MRT " Boot Mode Tool " All Are 512MB ROMS .
Spildit wrote:Of course that this is the generic method.
If the ROM is packed/compressed this will not work.
If you find a serial number it doesn't mean you can just change it as the ROM most likely will have a CRC and if you change the ROM without re-calculating the CRC it will not work.
Well,
I do not what to change serial no .Sure it will change CRC :D
@ Frank ,
Buddy Whats the location of this in that 512mb
May 4th, 2015, 7:05
Frank ,Spildit ,
Please Find Attachments
rom d-self.rar
(434.62 KiB) Downloaded 785 times
rom-13006 donor.rar
(434.69 KiB) Downloaded 694 times
rom.rar
(137.06 KiB) Downloaded 721 times
Rom-12793.zip
(213.9 KiB) Downloaded 653 times
May 4th, 2015, 7:48
rom d-self
00061640  FF FF FF FF 39 56 4D 56 4A 4D 32 39 30 30 30 30  ÿÿÿÿ9VMVJM290000
00061650  37 31 32 32 5A 4C 33 4E FF FF FF FF FF FF FF FF  7122ZL3Nÿÿÿÿÿÿÿÿ
00061660  FF FF 02 01 50 00 C5 00 2D 50 E1 BF 3F 05 FF FF  ÿÿ..P.Å.-Pá¿?.ÿÿ
00061670  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00061680  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00061690  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000616F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00061700  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00061710  31 32 30 32 32 30 31 30 01 FF FF FF FF FF FF FF  12022010.ÿÿÿÿÿÿÿ
00061720  FF FE 00 00 53 54 33 35 30 30 34 31 38 41 53 20  ÿþ..ST3500418AS
rom-13006 donor
00061640  FF FF FF FF 39 56 4D 34 4D 46 45 57 30 30 30 30  ÿÿÿÿ9VM4MFEW0000
00061650  37 30 32 38 4C 35 52 4E FF FF FF FF FF FF FF FF  7028L5RNÿÿÿÿÿÿÿÿ
00061660  FF FF 02 01 50 00 C5 00 09 FA 57 DF 3F 05 FF FF  ÿÿ..P.Å..úWß?.ÿÿ
00061710  30 39 31 37 32 30 31 30 01 FF FF FF FF FF FF FF  09172010.ÿÿÿÿÿÿÿ
rom
00010050  FF FF FF FF 39 56 4D 47 4B 59 31 4D 30 30 30 30  ÿÿÿÿ9VMGKY1M0000
00010060  4D 32 33 39 33 48 32 59 FF FF FF FF FF FF FF FF  M2393H2Yÿÿÿÿÿÿÿÿ
00010070  FF FF 02 01 50 00 C5 00 3C CB 33 7E 3F 05 FF FF  ÿÿ..P.Å.<Ë3~?.ÿÿ
00010080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00010090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000100F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00010100  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00010110  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00010120  30 33 30 35 32 30 31 33 01 FF FF FF FF FF FF FF  03052013.ÿÿÿÿÿÿÿ
00010130  FF FE 00 00 53 54 33 35 30 30 34 31 33 41 53 20  ÿþ..ST3500413AS
Rom-12793
00010050  FF FF FF FF 5A 32 41 42 47 4A 41 57 30 30 30 30  ÿÿÿÿZ2ABGJAW0000
00010060  43 32 30 36 39 58 4C 58 FF FF FF FF FF FF FF FF  C2069XLXÿÿÿÿÿÿÿÿ
00010070  FF FF 01 01 50 00 C5 00 36 1A 3B BA 3F 05 FF FF  ÿÿ..P.Å.6.;º?.ÿÿ
00010120  30 38 31 33 32 30 31 31 00 FF FF FF FF FF FF FF  08132011.ÿÿÿÿÿÿÿ
00010130  FF FE 00 00 53 54 33 31 36 30 33 31 36 41 53 20  ÿþ..ST3160316AS
May 4th, 2015, 10:54
fzabkar wrote:rom d-self
rom-13006 donor
rom
Rom-12793
Hello Frank ,
Thanks For This .I had tried to search using this hex editor and ascii search in there -> http://www.hhdsoftware.com/free-hex-editor
May 4th, 2015, 23:51
Amarbir wrote:I had tried to search using this hex editor and ascii search in there -> http://www.hhdsoftware.com/free-hex-editor
Free Hexeditor Neo is the only binary files editor that deals with large files faster than any other one!
Now that's an example of tautology if I ever saw one. :lol:
May 5th, 2015, 0:28
Well,
its Getting Deleted From My PC LOL .I do not need that speed haa haa right frank :mrgreen:
June 28th, 2015, 17:53
in terminal output pressing CTRL+L command shows serial number.
June 29th, 2015, 10:32
mikail13 wrote:in terminal output pressing CTRL+L command shows serial number.
Thanks ,
Might Be Useful For Someone
June 2nd, 2017, 22:36
Now Ctrl+L is useless at alone new PCB etc. st500dm002, st31000524as, st3500413as
how can i learn the rom's serial number without PC3K?
i have many disks with pcb mess.
maybe possible to read rom by means of transfering rom chip to old pcb?
June 3rd, 2017, 0:17
Amarbir[CDR-Labs] wrote:Hello ,
Yes Amarbir ji I have seen in most cases PCB Number 100535704 Rev C without connecting hard drive to PCB u can see Serial No. ROM chip
Recently I got Got 10-12 old 500g as Amarbir said models. some pcb interchanged . i checked with TTL. Most 100535704 Rev C Boards shown Serial No. And you may see the PCB serial No also. IN other PCB Nos I have not seen even F3 T> command too. I will try to post pics
June 3rd, 2017, 0:22
mikail13 wrote:Now Ctrl+L is useless at alone new PCB etc. st500dm002, st31000524as, st3500413as
May be In some cases u can Read.
June 3rd, 2017, 2:22
Amarbir[CDR-Labs], you can use winhex to show binary code
June 3rd, 2017, 9:29
Folks ,
You picked up a very old post :D ,Anyway everyone should be benefited who reads this
