 Post subject: MHDD on VMware
PostPosted: June 6th, 2017, 0:08
Hi guys.
I´m new in the forum but i has been using MHDD since 5 years, and it´s a magic tool for recover HDD´s :cool: , some clients and friends ask me to change theirs hard drives cause "It´s broken" and i scan it whit MHDD and... i fix it, in some cases say´s me to change the drive cause they don´t trust in the repair i do, any way, a few monts ago i had a computer for use MHDD and another tools for recover, cloning and repair HDD´s, but now it´s broken and i need my another computer for work in another stuff, now i think "why not use MHDD on VMware?" and i tried; I mounted the image on a virtual machine but don't work... i have no ide why, i ask you for help.
Someone tried to use MHDD on WMware an had succes on it?
(sorry for my bad english, i'm trying to learn the language :( )
Extra info
I´m have using the 12.0 version of VMware and the next configuration:
-Guest operating system: microsoft windows 98 (for more compatibility, i has tried windows 7 [x86 and x64] windows vista [x86 and x64] and windows XP [x86 and x64])
-number of procesors 1
-number of cores per procesor: 1
-RAM size: 2048
-I/O controler types; SCSI Controller: BusLogic (i have not idea if this configuration make it don't work, but i can´t skip it)
-virtual disk type: SATA (I tried also IDE but dosn't work, any way i not use the virtual drive)
-disk: create a new (i add the drive that i want to scan later).
 Post subject: Re: MHDD on VMware
PostPosted: June 6th, 2017, 18:51
Hmm, I think it will not work. MHDD needs direct access to the drive you want to test, and with VMware and the operational system running, you don´t have that. You can make a bootable cd / usb drive to use it.
PostPosted: June 7th, 2017, 23:34
You have reason, seeing the documentation, says that MHDD doesn't uses the BIOS for acces to the HDD.
MHDD acces to the controler then to the HDD, I will use MHDD as usually i do and in the way that always has worked for me.
Thank you very much,if anybody have succes using MHDD on VMware, please share what configuration used to.
