pcb issue
June 13th, 2017, 2:37
when we connect only hdd pcb to terminal by rs232 to ttl converter we get the error as in attachment .Do any one have any solution ,I dont need any data just i want to know the problem.
New Text Document.txt
(1.78 KiB) Downloaded 550 times
Re: pcb issue
June 13th, 2017, 15:30
pkvenkatesh wrote:when we connect only hdd pcb to terminal by rs232 to ttl converter we get the error as in attachment .Do any one have any solution ,I dont need any data just i want to know the problem.
The solution is to screw the PCB onto the drive.
Re: pcb issue
June 14th, 2017, 23:34
According to the suggestion will it work.
Re: pcb issue
June 16th, 2017, 14:10
Spildit wrote:
pkvenkatesh wrote:According to the suggestion will it work.
:shock: :shock: :shock:
No comment ....
Haa Haa ,
Spildit Now You Know How Hard Its To Deal In India :D
Re: pcb issue
June 16th, 2017, 18:44
Sadly, that kind of thing happens in other places too.
