 Post subject: No Terminal Responce
PostPosted: June 30th, 2017, 7:01
Model ST3500413As
fw jc45
PNO 9YP142-516
This drive is dead PCB(5.v TVS diode Short ) Changed PCB and changed eprom
Now Hdd detects Model No:ST_M13FQBL
Heads changed in clean room
PCB and Heads from same model, same FW , date code 45 days difference
Drive connected to Terminal
No terminal response Blank terminal
I am Using 5v adapter (not USB)
 Post subject: Re: No Terminal Responce
PostPosted: June 30th, 2017, 7:45
if model number appears as ST_M13FQBL. it means SA can not read and ID values load from ROM. It can be a complicated problem maybe media damage.
PostPosted: July 1st, 2017, 4:13
prasadsv wrote:
... Changed PCB and changed eprom
Is ROM original or you change it for donor ROM?
PostPosted: July 1st, 2017, 5:54
Original Rom swap
PostPosted: July 1st, 2017, 6:16
prasadsv wrote:
Original Rom swap
I mean Original ROM to new PCB
PostPosted: July 1st, 2017, 6:18
If drive are not clicking so upload overlay.
PostPosted: July 1st, 2017, 6:37
Just I observed Clicking Very very low sound 4 to 5 times and becomes normal spin
PostPosted: July 1st, 2017, 7:46
Heads are good, but drive can't load important elements from SA, overlays usually. So upload overlay.
PostPosted: July 7th, 2017, 8:58
So upload overlay.?
PostPosted: July 7th, 2017, 10:28
prasadsv wrote:
So upload overlay.?
Any issue with this sentence?
PostPosted: July 9th, 2017, 14:41
May be The drive Family have problem. Other working drive of this same Family also no terminal output . I checked 3 hdd
PostPosted: July 16th, 2017, 6:20
ST3500413AS JC65 9YP142-542, same family, newer fw. and p/n.
Normal terminal output.
Rst 0x10M
RW: Disc Ctlr Initialization Completed.
(P) SATA Reset
ASCII Diag mode
F3 T>
Those who know don’t talk. Those who talk don’t know.
PostPosted: July 16th, 2017, 15:22
Rst 0x10M
(P) SATA Reset
ASCII Diag mode
F3 T>
what adapter did you used?
I used Max232
I think issue with adapter(5v)
PostPosted: July 16th, 2017, 20:21
Use a 3.3V adapter.
PostPosted: July 17th, 2017, 0:46
On this fw version terminal will appear as soon as DiskFW will be loaded.
PostPosted: July 17th, 2017, 5:13
I used Max232
max232a (connected to profilic usb to com adapter)
PostPosted: July 17th, 2017, 12:14
Use a 3.3V adapter.
It need 1.8v or 2.4 v? on both tx rx ports?
