 Post subject: Favourite Seagate Slim Nightmare - Suggestions And Help Reqd
PostPosted: July 14th, 2017, 7:17
Hello All,
I Have A Few Seagate Slim Series HDD with Different Terminal Reports ,Can You Folks Help and suggest Me If Replacing Heads Could Help In The Case Or Its a Firmware Nightmare :lol:
1 : Drive A [ 01325 ]
Terminal Report " No Clicking "
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
PrgF
(MC POR Duration): 0000000097
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
FAFH_TRIGGER_POWER_UP
CTRL+A = Drive Info As Under
Prod Desc: CheopsLiteM.1.0.SATA.Rosewood.Mule.Servo376.Rap30.AP1.4K + SMR Despo DFW
Package Version: RO08B6.SDM2.CC4638.SBM3
Serial #: WDE2AM6G
Changelist: 01138956
Model #: ST1000LM035-1RK172
Servo FW Rev: 6B68
Heads: 2
PCBA SN: 0000K720S5PK
Default factory config: SD&D
Active config: SD&D
TotalHostWrites 00000000
NumberOfSegWrites 0000
TotalHPCBROs 00000000
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0000
MCSegmentUsed 0000
MCNodeUsed 00000000
Status : Drive Shows Ready , No ID In PC 3000 Id Section ,No User Area Access ,If Heads Are Replaced Can there Be Any Chances On Recovery ,Drive is ST1000LM035
Last edited by Amarbir[CDR-Labs] on July 14th, 2017, 7:24, edited 3 times in total.
 Post subject: Re: Favourite Seagate Slim Nitemares - Suggestions And Help
PostPosted: July 14th, 2017, 7:22
Drive 2 [ 01196 ]
Terminal Report " Drive Clicks Too "
Boot 0x80M
QB
(P) SATA Reset
RAW OFF
PASS
(POR) Recover Secondary MCMT Opened
FAIL Servo Op=01A5 Resp=0007
01A5 6FFF 0004 7FFF 7FFF 7FFF 001C 0B21 4142 0000 03E8 4200 FFFF 05C0 0000 0000 0000 82FF
UnvRdStatus1: 0x00004500
UnvScntLdData: 0x00000031
SrvVrtSectNum: 0x00000122
MmValidServo: 0x00000000
MmExtServoNum: 0x000000392871 0000 0000 FF20 6666 A031 0000 7009 0000 0000 0000 0000 0000 0000
ResponseFrame 0002 0010 0003 0420 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 12BC 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
FAIL Servo Op=06DF Resp=0007
06DF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0101 F842 1020 E001 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 4B52 F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 0000
DSC FAIL
01A5 6FFF 0004 7FFF 7FFF 7FFF 001C 0B21 4142 0000 8000 4200 FFFF 05C0 0000 0000 0000 82FF 2871 0000 0000 FF20 6666 A031 0000 7009 0000 0000 0000 0000 0000 0000
ResponseFrame 0002 0001 0001 C715 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 BD09 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 C0BD 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 CA2C 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
HPSR
FAIL Servo Op=0400 Resp=0003
0400 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame E722 0010 0001 CA2C 2900 D006 F7FF F92A 485D 495E F8D0 01A0 6008 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 0001
ResponseFrame E722 0010 FFE6 0001 0000 CF75 000D FFC3 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 0001
ResponseFrame 0002 0001 0001 C631 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 8770 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 735F 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 867F 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 3AC1 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
HPSR
ResponseFrame E722 0010 0001 3AC1 0000 CEEE 000E FFC2 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 0001
ResponseFrame E722 0010 FFE5 0000 0000 CEEE 0011 FFC3 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 0001
ResponseFrame 0002 0001 0001 9F49 0000 CF0A 000A FFC3 0000 0001 00CA 01A0 0000 BD10 13FC F503 6280 F8B3 0322 B148 F8D2 02A0 F5B0 3FBC 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
Problem : Drive Clicks " ST1000LM035" ,Can a Head Swap Solve This issue or then i will get stuck in a firmware nightmare issue
 Post subject: Re: Favourite Seagate Slim Nightmare - Suggestions And Help
PostPosted: July 14th, 2017, 7:33
Drive 3 [ 01195 ]
Terminal Report " ST2000LM007 " , Drive Starts Reads Some Firmware and Then Clicks To And Keeps Clicking
Boot 0x80M
QB
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000F92 At SU: 000049F6 NT: 00000000 OT: 0000000B
(POR) Recover Secondary MCMT Opened Recovered
(MC POR Duration): 0000000129
Intel 6G->3G
CSpd= 3Gbps
ResponseFrame 0000 0001 0000 0001 0008 0000 0000 0000 0DFB 0000 0000 0000 0000 0000 1A27 0E2E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000D Loop=2247
DSC FAIL
ServoDiscSlip Failed ErrCode = 0415018B
RECOV Servo Op=0295 Resp=0005
(DOS) SU:000D6589 Ct:00000A98 Adjusted BRO: 000552AF1B - 000552DB82
FAIL Servo Op=0395 Resp=0007
0395 FFFD FFFF 7FFF 7FFF 7FFF 0000 0003 0000 0000 03E8 0000 FFFF 1480 0000 0000 004D 02BC 2871 0000 0000 D980 428B A000 0000 0000 0000 0000 0000 0000 D900 0000
ResponseFrame 0000 0001 0821 0008 0008 0000 0000 0095 063B 0000 0D3B 0000 143B 0000 1930 0E2E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 001C Loop=2247
ResponseFrame FB10 F002 EBA1 30A0 F8A4 037E F7FF FF84 F7FF FF3C 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 Loop=2247
(DOS) SU:000D6555 Ct:00000A78 Adjusted BRO: 0005525F7B - 0005527FA2
FAIL Servo Op=000E Resp=000B
000E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 0001 0000 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1737 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 002D
0395 AEC5 0001 7FFF 7FFF 7FFF 0000 0003 0000 0000 03E8 0000 FFFF 89A0 0000 0000 004B 02BC 2871 0000 0000 C950 426A A000 0000 0000 0000 0000 0000 0000 DF00 0000
ResponseFrame 0000 0001 0000 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1737 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 002D Loop=2247
0395 AEC5 0001 7FFF 7FFF 7FFF 0000 0003 0000 0000 8000 0000 FFFF 89A0 0000 0000 004B 02BC 2871 0000 0000 C950 426A A000 0000 0000 0000 0000 0000 0000 DF00 0000
ResponseFrame 0002 0001 0001 C85A F8A4 037E F7FF FF84 F7FF FF3C 0000 0000 0000 0000 1737 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 C465 F8A4 037E F7FF FF84 F7FF FF3C 0000 0000 0000 0000 1737 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
ResponseFrame 0002 0001 0001 D6F6 F8A4 037E F7FF FF84 F7FF FF3C 0000 0000 0000 0000 1737 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2247
Problem : Drive Starts , Reads Firmware ,ID's Fine ,But Then Keeps Clicking ,Will Head Swap Solve This or Again i will be stuck in a Situation of a Firmware Issue
PostPosted: July 14th, 2017, 13:04
All three drives were able to load majority of SA, so I would guess the heads are fine on all three
PostPosted: July 15th, 2017, 2:43
Guru Doomer ,
Good Morning Sir ,The First One Does Not Click ,The Second One Is Clicking ,the third One Clicks After Reading Some SA and Keeps Clicking
PostPosted: July 15th, 2017, 11:10
I can see that but it does not change the fact that they all we able to read DiscFW and translator
Second and third are clicking on accessing media cache, maybe some servo issues there
PostPosted: July 16th, 2017, 0:34
Alright ,
Thanks For the support Always Appreciate It As a Junior In Field . I Have Ordered Some Head Replacement Tools For The Same Series Drives .I Have Also started To Collect Some Donors For The Same ,Lets See What We Can Do in The Coming Months With these Drives .I Would Be Investing in a Logic Analyzer Soon For RE Some Stuff Here And There But Basically For Monoliths
Users browsing this forum: Google [Bot] and 59 guests
