 Post subject: SAMSUNG HD753LJ
PostPosted: July 19th, 2017, 11:34
http://monitor.espec.ws/files/78477_159.jpg
Hello!
Where is the firmware chip on this hard drive?
Could it be found under the board?
Can i flash this chip with CH341A EEPROM CLIP?
 Post subject: Re: SAMSUNG HD753LJ
PostPosted: July 19th, 2017, 18:25
The flash memory is embedded within the Marvell MCU.
Assuming that the PCB is not dead, can you provide a terminal log?
How to connect a terminal adaptor on a Samsung drive ?
http://www.hddoracle.com/viewtopic.php? ... =189&p=432
Otherwise, what are the symptoms?
PostPosted: July 21st, 2017, 1:48
the large size M88i.....
Users browsing this forum: Google [Bot], Lukas, qwest01 and 50 guests
