 Post subject: maxtor diamond 10 - 250 gb ata 133
PostPosted: July 16th, 2017, 14:58
maxtor diamond 10 250 gb ata 133 (ide)
i need rx, tx, gnd pin connections can cany one help on this?
is my old device his work well i need recovery any files over them.
 Post subject: Re: maxtor diamond 10 - 250 gb ata 133
PostPosted: July 18th, 2017, 2:32
It is Sabre family, native Maxtor. TTL is avilable via safe mode, it will help if there is a problem with SA.
PostPosted: July 18th, 2017, 17:43
As I remember, to get into safe mode you have to send signal for initializing a safe mode, not a shorting a pins.
PostPosted: July 19th, 2017, 14:12
I think Martin is referring for SATA Maxtor drives.
PostPosted: July 19th, 2017, 19:08
For Sabre family see pic how to connect wire for safe mode:
My firmware database:
PostPosted: July 20th, 2017, 13:11
Yes, I forget that Sabre uses both types of PCB. Didn't work with ATA for a long time.
P.S. As I can see, Michel had provide short pins for SATA (hybrid) as well.
Users browsing this forum: No registered users and 90 guests
