 Post subject: Help finding TVS diode on Seagate ST3200822A
PostPosted: May 4th, 2017, 13:44
Hello everyone. After a long search for this drive on the forum to replace the TVS diode i cant find anything.
In this pcb is not very clear and the letters/numbers on the components not resolve anything at all after looking for it on google.
Can anyone help me to find the TVS diode? I dont know if this drive have one or two (+5 and +12). In other topics ive seen, a temporal (and risky) solution to turn on the hdd, is unsolder the bad tvs diode. That is exactly what i need, to make a quick copy on other drive. This will work?
Thanks and sorry for my english.
Pics:
 Post subject: Re: Help finding TVS diode on Seagate ST3200822A
PostPosted: May 4th, 2017, 13:59
Here I Marked with Red color both !2V and 5V
PostPosted: May 4th, 2017, 14:27
Hi Copemcor,
What makes you assume it's the TVS? Does it shut off the computer power supply when you plug it in?
PostPosted: May 4th, 2017, 14:37
data-medics wrote:
Hi Copemcor,
Yes, i've tried 4 different mobo and when i plug the hdd, the system dont do anything, stays completely dead.
PostPosted: May 4th, 2017, 14:41
Thanks a lot prasadsv. Do you recomend me to unsolder the bad tvs to make a quick copy? Very risky? Will it work?
PostPosted: May 4th, 2017, 14:44
First Check the diodes with multimeter
You Have checked with 4 PCB ?
Same complaint ?
Some time it may happens with power supply also
PostPosted: May 4th, 2017, 14:48
Same complaint ?
I mean 4 differents computers with differenet power suply
PostPosted: May 4th, 2017, 14:52
Same complaint ?
Then proceed checking diodes
PostPosted: July 31st, 2017, 4:53
I am not quite sure about it. If you find the way to solve it, just tell me.
Users browsing this forum: Google [Bot] and 33 guests
