 Post subject: Seagate F3 ST3500418AS service area
PostPosted: August 1st, 2017, 8:32
Hello dear experts,
I have got a 'dead' subject hdd from 2011 (in 2011 i brought it in two Data Recovery companies, spent 350eur onto diagnostics, they said the service area is dead, very expensive data recovery[per megabyte] (i need something about 10gb out of 40gb pictures on it, dont know even the exact filenames, folders i need).
As i understand the ROM with the adaptation values has become corrupt, now 6 years have passed, maybe some not-so-expensive recovery methods have shown up?
I bought a RS232 converter to check the error messages (managed to corrupt the translator on one of my spare donor drives, while playing with it,lol :) )
What the actual disk, who needs recovery, does at startup in terminal-
RW: Error processing Performance Parameter File: 203C
No Phy: Staggered spin bypass
Does not respond to ctrl+z or anything, not being detected in bios.
I dont that data that much, that i would be ready to pay tons of money, so maybe you can give some advice, what to try?
I have one more untouched donor disk with same model, firmware version. Open for experiments.
Thank you.
 Post subject: Re: Seagate F3 ST3500418AS service area
PostPosted: August 2nd, 2017, 7:14
without any Professional Tools your drive cant be done you will be just wasting money on donors ...
if Drive is not clicking, you have not open disk yet & Drive Original ROM is attached any professional company can do it for under 500$...
PostPosted: August 2nd, 2017, 8:23
this error show when head is weak please wait for show terminal and give command :----
(P) the SATA the Reset
the PASS
RW: the Error the Performance the Parameter File Processing: 203C
No the Phy: Staggered drive Spin Bypass
the ASCII MODE Diag
the F3 T> / 2
the F3 2> X1
the System the Partition
LBAs 00000000-000BAF4F
PBAs 00000000-000BBD9F
HdSkew 006E, CylSkew 0018
ZonesPerHd 02
Head 0, PhyCyls 03B8D9-03BA2C, LogCyls 000000-000152
the Physical the Logical Sec the Sym the Sym the Data
of Zn Wedge Cylinders Cylinders Track Track Rate
00 03B8D9-03B982 000000-0000A9 0394 063D 00072AE0 592.500
01 03B983-03BA2C 0000aa-000153 0394 063D 00072AE0 592.500
Head 1, PhyCyls 03E1FD-03E3F0, LogCyls 000000-0001F2
the Logical the Sym the Sym the Data Sec the Physical
00 03E1FD-03E2F6 000000-0000F9 0394 063D 00072AE0 592.500
01 03E2F7-03E3F0 0000FA-0001F3 0394 063D 00072AE0 592.500
the F3 2> A0
the Current Mode Addr
the User Mode LLL the CHS
Hd 0 Cyl 000000
All Addr Modes
the User the LBA Mode
LBAs 00000000 - 3A38602F
the System the LBA Mode
LBAs 00000000 - 000BAF4F
the User LLL the CHS and the User LLP CHW Modes
Hd 0 Cyls 000000 - 03B6DA
Hd 1 Cyls 000000 - 03DFED
the System LLL the CHS and the System LLP CHW Modes
Hd 0 Cyls 000000 - 000 152
Hd 1 Cyls 000000 - 0001F2
the PLP the CHS and the PLP CHW Modes
Hd 0 Cyls 000000 - 03BA2C
Hd 1 Cyls 000000 - 03E3F0
Buffer Sector Offset 00000000
the F3 2> s3B8D9,0,22
the F3 2> R, 0,3
the F3 2>
Blks 00109D -00109D (000001), BUFADDR 00213A00-00213BFF, the DBA 06213A00, Cmd 200 BytesPerBlk the Input Buf
Blks 00109E-00109E (000001), BUFADDR 00213C00-00213DFF, the DBA 06213C00, BytesPerBlk 200 Diag Batch File
Blks 00109F-00109F (000001), BUFADDR 00213E00 -00213FFF, the DBA 06213E00, BytesPerBlk 200
Blks 0010A0-0010A0 (000001), BUFADDR 00214000-002141FF, the DBA 06.214 million, BytesPerBlk 200
Blks 0010A1-0010A1 (000001), BUFADDR 00214200-002143FF, the DBA 06.2142 million, BytesPerBlk 200
Blks 0010A2-0010A2 (000001 ), BUFADDR 00214400-002145FF, the DBA 06.2144 million, BytesPerBlk 200
Blks 0010A3-0010A3 (000001), BUFADDR 00214600-002147FF, the DBA 06.2146 million, BytesPerBlk 200
Blks 0010A4-0010B7 (000014), BUFADDR 00214800-00216FFF, the DBA 06.2148 million, BytesPerBlk 200 Online Cmd the DFB SDBP
Blks 0010B8-0010CB (000014), BUFADDR 00217000-002197FF, the DBA 06.217 million, the Symbol the Error 200 BytesPerBlk the Map the Log
Blks 0010CC-0010DF (000014), BUFADDR 00219800-0021BFFF, the DBA 06.2198 million, the Test-Service BytesPerBlk 200 SDBP the DSB
Blks 0010E0-0010F3 (000014), BUFADDR 0021C000-0021E7FF, the DBA 0621C000, BytesPerBlk 200
Blks 0010F4-00113B (000048), BUFADDR 0021E800-002277FF, the DBA 0621E800, BytesPerBlk 200 Diag Mode Cmd SDBP the DFB
Blks 00113C-001 183 (000048), BUFADDR 00227800-002307FF, 06.2278 million the DBA, BytesPerBlk 200
Blks 001184-0011CB (000048), BUFADDR 00230800-002397FF, the DBA 06.2308 million, BytesPerBlk 200 Drive Info Journal of the Geometry
Blks 0011CC-001 213 (000048), BUFADDR 00239800-002427FF, the DBA 06.2398 million, BytesPerBlk 200
Blks 001214-00125B (000048 ), BUFADDR 00242800-0024B7FF, the DBA 06.2428 million, BytesPerBlk 200
Blks 00125C-0012B5 (00005A), BUFADDR 0024B800-00256BFF, the DBA 0624B800, BytesPerBlk 200
Blks 0012B6-00130F (00005A), BUFADDR 00256C00-00261FFF, the DBA 06256C00, BytesPerBlk 200
Blks 00223A -00298A (000751), BUFADDR 00447400-005315FF, the DBA 06.4474 million, the Default BytesPerBlk 200 Diag Rd Buf
Blks 00298C-0030CD (000 742), BUFADDR 00531800-0061B907, the DBA 06.5318 million, the Default BytesPerBlk 204 Diag Wrt Buf
the ASCII MODE Diag
the F3 T> / 2
the F3 2> B223A, 223A
Buffer Block 223A compared to Buffer Block 223A (204 Bytes / Block)
Addr 0 1 2 3 4 5. 6. 7. 8. 9 the A B C D E F.
00.4474 million 01 00 the FF the FF 00 00 00 00 the FF the FF the FF the FF the FF the FF the FF the FF
00.44741 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,420 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,430 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447440 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,450 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447460 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00.44747 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00.44748 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,490 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF CF3 the FF the FF the FF the FF the FF
004474A0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004474B0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004474C0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004474D0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004474E0 the FF the FF the FF the FF the FF the FF the FF the FF the FC the FF the FF the FF the FF the FF the FF the FF
004474F0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447500 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00.44751 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447520 the FF the FF the FF the FF the CA 61 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00.44753 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447540 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00.44755 million the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,560 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,570 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447580 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,590 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475A0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475B0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475C0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475D0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475E0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004475F0 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the AE 15 the FF the FF
00447600 the FF the F1 the FF the FF
the F3 2> B223B, 223B
the Buffer the Block 223B compared to the Buffer the Block 223B (204 Bytes / the Block )
the Addr 0 1 2 3 4 5. 6. 7. 8. 9 the A B the C the D the E F.
00,447,604 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447614 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,624 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,634 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447644 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447654 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,664 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447674 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447684 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,694 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476A4 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476B4 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476C4 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476D4 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476E4. 3F 53 the FF the DF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
004476F4 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,704 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00447714 the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF the FF
00,447,724 the FF the FF the FF the FF the CB 61 the FF the FF the FF the FF the FF the FF 55 the A8 55 of AA
00,447,734 55 of AA 45 of AA 55 of AA 75 of AA 55 of AA 55 of AA 54 AA 51 AA
00,447,744 55 the A8 55 AA 55 AA 55 AA 55 AA 55 AA 55 the A8 55 AA
00,447,754 57 AA 55 AA 57 AA 55 AA 55 AA 54 AA 55 AA 55 AA
00,447,764 D5 AA 55 A2 55 AA 55 the A8 55 AA 55 AA 55 the A8 55 AA
00,447,774 55 AA 55 AA 55 AA 55 A2 55 AA 45 AA 45 AA 55 AA
00,447,784 55 AA 45 AA 55 the A8 D5 AA 55 AA 54 AA 54 AA 55 AA
00,447,794 57 BA 55 AA 51 AA 55 A2 75. 2A 55 AA 55 AA 55 AA
004477A4 55 AA D5 AA 55 AA 15 AA 55 AA D5 AA 55 AA 55 AA
004477B4 55 AA 51 AA 55 AA 51 AA 55 AA 55 AA 55 AA 15 AA
004477C4 55 AA 15 AA 55 AA 55 AA 55 AA 51 AA 55 AA 5D AA
004477D4 15 A2 55. 2A 55. 2A 54 AA 54 AA 55 AB 55 AA 54 AA
004477E4 55 AA 54 AA 55 AA 55 AA 55 the A8 55 AA 5C AA 55 AA
004477F4 55 AA 55 AA 55 A2 55 AA D5 AA 75 AB D0 6E 75 AB
00,447,804 55 AA 55 AA
the F3 2> B223C, 223C
Buffer Block 223C compared to Buffer Block 223C (204 Bytes / Block)
00,447,808 55 AA 55 AA 55 AA 54 A2 55. 8A 55 AA 45 AA 54 AA
00,447,818 55 AA 55 AA 55 AA 7C AA 55 AA 51 AA 55 AA 55 the A8
00,447,828 55 BB 55 AB 5D AA 55 AA 54 AA 55 AA 74 AA 55. 2A
00,447,838 55 AA 55 AA 55 AA 55 AA 57 AA 15. 2A 55 AA 55 the A8
00,447,848 55 AA 55 AA 55 AA 55. 2A 54 AA 55 AA 55 AA 55 AA
00,447,858 55 AA 54 AA 45 AA 55 BA 55 AA 57 AA D4 AA 55 AA
00,447,868 55 AA 55 AA 57 AA 55 AA 55 AA 55. 3A 55 AA 55 AA
00,447,878 55 AA 55 AA 51 the A8 D3 AA 55 AA 55 AA 55 AA 55 AA
00,447,888 55 the EA 45 the AE 55 AB D4 A2 55 AA 55 AA 55 AA D5 AA
00,447,898 51 A2 54 AA 55 AA 5D AA 01 AA 55 AA 51 AA 55 AA
004478A8 55 AA 55 AA 55 AA 55 AA 55 AA 55 AA 55. 8A 54 AA
004478B8 5D AA 55 BA 55 B8 15 AA 51 AA 55 AA 55 AA 54 AA
004478C8 55 . 8A 55 the A8 55 AA 55. 2A 55 2E 55 AA D5 AA 55 AA
004478D8 15 AA 55 AA 55. 8A 55. 8A 55 AA 45 AA 15 AA 55 AA
004478E8 55 AA 15 B8 05. 2A 55 AA 45 AA 51. 8A 55. 2A 15 AA
004478F8 54 AA 51 AA 5D AA 55 the A8. 11 AB 51 AA 45 the AE 51 AA
00,447,908 55 2B 5D. 2A 55 A2 55 AA 55 AA 55 AA 55 AA 55 AA
00,447,918 55 AB 55 BA 55 AA 55 AA 51 AA 51 AA D5 AA 55 the A8
00,447,928 55 AA 51 the EA 20 81 51 the EA 55 AA 55 AA 55 AA 55 AA
00,447,938 55 AA 5D BA 55 AA 55 AA 55 AA 55 A2 55 the A8 55 AA
00,447,948 55 AA 55 AA 45 AA 55. 2A 55 AA 55 AA 55 the A8 55 AA
00,447,958 45 AA 55 AA 55 AA 54 8E 55 AA 51 AA 57 AA 55 AA
00,447,968 55 the A9 55 AA 57 AA 55 AA 55 the AE 55 AA 55 A2 55 BA
00,447,978 55 AA 55 AA 55 AA 55 the A8 15 AA 54 AA 55 the EA 55 AA
00,447,988 55 AA 55. 8A 55 AA 55 the EA 55 AA 55 AA 55 A2 D7. 8A
00,447,998 5D BA 55 AA 55 AA 55 AA 75 AA 51 AA 55 2E 55 AA
004479A8 55 2B 55 AA 55 AA 55 AA 55 AA 55 AA 55 A2 55 AA
004479B8 55 AA 55 AA 55 AA 55 AA 55. 2A 54 AA 55 AA 55 AA
004479C8 55 AA 55 A2 55 AA 54. 8A 55 the AE 51 AA 55 A2 55 AA
004479D8 15 AA 55 AA 55 AA 55 AA 55 AA 5D AA AA 55 AA 55
004479E8 0A 55 55 AA 54 AA 55 AA 5D AA 55 AA 55 AA 15 AA
004479F8 5D AA 55 AA 55 AA 55 AA BA 4D 3B D4 BA 55 BA 55
00447A08 the EA DD AB 55
the F3 2>
PostPosted: August 2nd, 2017, 8:24
but own risk
PostPosted: August 6th, 2017, 12:55
galaxy wrote:
but own risk
Well,
What are you trying to do in the terminal it flew off my head
Users browsing this forum: nicola and 255 guests
