 Post subject: Terminal giving me some crazy stuff
PostPosted: August 10th, 2017, 10:21
This is what i get when i connect to my 3.5 samsung 500gb HD502HJ. I cant even type commands.
 Post subject: Re: Terminal giving me some crazy stuff
PostPosted: August 11th, 2017, 0:01
incorrect speed
PostPosted: August 11th, 2017, 1:43
So what speed should i use ?
PostPosted: August 11th, 2017, 1:48
It should be 56700
PostPosted: August 11th, 2017, 2:08
Ok i will try thank You. Btw how You know what speed should be used ?
PostPosted: August 11th, 2017, 2:43
Because I have been doing this for 10+ years!! :-)
PostPosted: August 11th, 2017, 3:24
Ok can You share the info how to identify what speed to what drive ?
PostPosted: August 11th, 2017, 3:33
As soon as you pay a "thank-you" fee :D
PostPosted: August 11th, 2017, 6:04
Thank You
PostPosted: August 11th, 2017, 7:54
you find a list of common baud speeds. then you try them. you wont hurt anything by wrong speed.
not specifically hard disks, but anything you connect to a serial terminal is pretty easy to find, normally one of 4 common ones. Some devices start with one speed, then part way into the boot, switch to a different one. It isn't common.
As masterclass implied, the more you play around with it, the easier it is to find out what you need.
good luck
PostPosted: August 11th, 2017, 7:55
duplicate post
PostPosted: August 12th, 2017, 8:11
pcimage wrote:
It should be 56700
Its still not the right speed or i am doing something wrong.
I connect Samsung 3.5" SATA [ '''''''''''''''| |''''''''' ] [::::]
. <- RX
. <- TX
PostPosted: August 12th, 2017, 9:11
Green RX white TX
PostPosted: August 12th, 2017, 10:35
try 38400. is it a Samsung MCU?
are you connecting the ground wire as well?
you might try this tool to discover baudrate:
https://code.google.com/archive/p/baudrate/
it is a python script
show a photo of your setup.
usually you would try the common ones in order
try 1: 19200
try 2: 38400
try 3: 57600
try 4: 115200
then switch RX TX and try again. usually one of the middle 2 though. Otherwise maybe the adapter isn't right. some are finicky with TTL adapters. you should have at least 2 with different chipsets just in case. I have had problems with ones that have a PL2303 chip. But better with ones that have CP2102 or CP2103
if you think that just banging away until you get it is non-professional, this quote is from the Atola insight forensic tool manual:
Should there be no output in the Terminal window or should it consist of random symbols, try to change the Baud rate until you get a good response.
PostPosted: August 12th, 2017, 11:18
I have used all the speeds same problem i use putty
data 8
stop 1
parity none
flow none
not connecting ground wire
Why when i want to add picture on forum it says it need to be verified with moderator...
PostPosted: August 12th, 2017, 11:19
tinyurl . c o m / yazsbj8y
Here are the photos of my connection and drive the letter on processor is M
PostPosted: August 12th, 2017, 13:15
It seems i have that shitty one PL2303 :(
PostPosted: August 12th, 2017, 17:16
How are you powering the HDD? ISTM that your PSU and the USB-TTL adapter may not be sharing a common ground, in which case you may need to connect the adapter's ground wire to your HDD.
Users browsing this forum: Google [Bot] and 246 guests
