 Post subject: Samsung 2.5 - ST2000LM003 Error LED 0001
PostPosted: September 6th, 2017, 13:49
Don't recognized and clicking. A long time ago , consumer let the hdd to fall, but continued to using the hdd.
After the clicking : (at the end, show LED 0001)
VDAC Offs K0 ............Done: 57
VN on
SHK on
VBEMF Offs ....Done
VBEMF Gain ....Done
A1O= 10 A2O= 4 SWO= - 7
A1G= 1339 A2G= 7 SWG= - 2
Rvcm= 11038 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
VN off
SHK off
PK_3 C: 0 H:2
VN on
SHK on
VBEMF Offs ....Done
VBEMF Gain ....Done
A1O= 10 A2O= 4 SWO= 0
A1G= 1337 A2G= 7 SWG= 23
Rvcm= 11025 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
VN off
SHK off
PK_3 C: 0 H:3
Unlatch Fail
EPOK
UDed
PK_4 C: 0 H:4
UDed
PK_4 C: 0 H:4
LED 0001
LED 0001
LED 0001
LED 0001
LED 0001
LED 0001
Maybe heads or scratched media ?
HD RECOVERY
Sao Jose do Rio Preto - SP
BRAZIL
+55 17 32276226
+55 17 99639-0175
 Post subject: Re: Samsung 2.5 - ST2000LM003 Error LED 0001
PostPosted: September 6th, 2017, 23:25
ISTM that the headstack is stuck at the load/unload ramp.
PostPosted: September 7th, 2017, 1:52
can't be if the OP says:
waranha wrote:
Don't recognized and "clicking."...
"After the clicking" : (at the end, show LED 0001)
most be according to the log:
PostPosted: September 7th, 2017, 16:56
So what do these mean?
    LD..Stuck
    UD..Stuck
    Unlatch Fail
PostPosted: September 7th, 2017, 17:27
i guess it can't catch servo during unlach so it fails...
My first bet was stuck heads too, but reading the full post makes it clear it is not stuck.
PostPosted: September 7th, 2017, 19:11
The drive appears to have failed to detect the servo on all 5 heads ???
Could this point to a PCB failure? Bad read channel? Dirty HDA contacts?
PostPosted: September 8th, 2017, 3:25
i guess
if the drive was here i could tell it in minutes but by log...
on the other hand it might have got stuck in the meantime, but then it has 2 problems now: clicking and sticktion.
I am also not sure if this model checks servo on all heads or just fails if it can't find it on H0.
this is what's easy to sort out with proper tooling and knowledge even if we don't have log... but we need physical access to the drive.
PostPosted: September 8th, 2017, 5:08
Maybe heads are stuck between the ramp and the platters which means platters rotate and heads click, drive can't load and unload and unlatch fails.
As pepe said, we're only guessing here.
Users browsing this forum: No registered users and 38 guests
