Toshiba DT01aca100 series issues
September 11th, 2017, 6:52
Hello Friends,
i m new in this forum sir one toshiba harddrive dt01aca100 pcb vcm motor ic burn, i replace the head no spinning then pcb and swap nvram but no movement my nvram is also faulty but in mrt rom programmer it is read and then rom file write in a new rom and swap to donor pcb now harddrive is spinning but no detection.. what is the head swapping rule for toshiba dt01aca100 and dt01aca200 model harddrives. and how i can solve this case with MRT. Pls help friends..
