 Post subject: Repair of fallen WD20EARX ( Caviar Green) USB External ?
PostPosted: September 29th, 2017, 19:26
Hello friends
my WD20EARX felt yesterday from height of 1m approx. But it was not powered.
Since then its no more recognized in Mac OS X Sierra neither Win 7.
WD Drive utilities recognize only that there is a "Mybook" attached, but no volume inside , 0 byte... i guess it reads only PCB memory to show that ?
When clinking check drive status, it shows error reading SMART parameters in red
When started, we hear traditional clicks of heads moving and trying to read 2 or 3 times only, then heads click sound disappear.
Only the motor sound remains for 1mn or 2mn. and then it goes for another cycle of some heads moving clicks , then stop again.
PCB led blinks continuously quickly.
Sometimes after these cycles finished , disk completely stops automatically, with no activity, no led, like power was cut. If i replug USB cable to start it soon after, then it doesn't make any mechanical noise, only led blinking fast.
To get the motor sound, i have to replug the power cable.
Sorry if this is stupid or naive from me, but do you think it's a mechanical problem , or it can be PCB related ? or the HDD mechanic is dead ?
ps:Tried to put it in the freezer for one night ( old technic from an old fashioned IT guy :)
Thanks for your help.
James
 Post subject: Re: Repair of fallen WD20EARX ( Caviar Green) USB External ?
PostPosted: September 29th, 2017, 22:47
Broken heads. No hope.
PostPosted: September 30th, 2017, 3:29
Yes heads gone, if data is wanted take it to a data recovery center.
http://www.rescue-it.se
PostPosted: September 30th, 2017, 4:32
Freezing it will have probably made things worse, bad move sorry to say :-(
Users browsing this forum: No registered users and 60 guests
