 Post subject: Samsung ST2000LM005 Sata PCB conversion - 100732076 Rev B.
PostPosted: September 29th, 2017, 13:01
Anyone know a compatible SATA board for the Samsung/Seagate 100732076 Rev. B?
 Post subject: Re: Samsung ST2000LM005 Sata PCB conversion - 100732076 Rev
PostPosted: September 29th, 2017, 17:18
100739392 should work, i successfully solved a case with your same usb pcb that was faulty.
My firmware database:
PostPosted: September 29th, 2017, 17:40
Do you really need to replace the PCB? Some Samsung PCBs have problems with dry solder joints at the chip inductors. If yours is one of these, then a quick reflow with an iron is all that it needs. Just saying ...
Users browsing this forum: Google [Bot] and 51 guests
