 Post subject: Hitachi 5K750-500 Password reset?
PostPosted: October 27th, 2017, 18:51
Client has a Hitachi 5K750-500 hard drive that was installed in a Dell laptop. According to them they had recently changed the hard drive password and shortly after that the laptop ran into a motherboard issue. I repaired the motherboard and when they came to pick it up they tried entering what they thought was the correct password but weren't able to gain access. Interestingly enough, this drive appears to have been pulled from a MacBook at some point since it is identified as an Apple drive. I did try unlocking using the 32 space master password but no luck, I don't believe that is valid for this model. If there's no way to unlock, is it still possible to do a secure erase? HDPARM output follows:
ATA device, with non-removable media
Model Number: APPLE HDD HTS547550A9E384
Serial Number: J266004BG5BGKG
Firmware Revision: JE3AD70F
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6; Revision: ATA8-AST T13 Project D1697 Revision 0b
Standards:
Used: unknown (minor revision code 0x0028)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 976773168
Logical Sector size: 512 bytes
Physical Sector size: 4096 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 476940 MBytes
device size with M = 1000*1000: 500107 MBytes (500 GB)
cache/buffer size = 8192 KBytes (type=DualPortCache)
Form Factor: 2.5 inch
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 0
Advanced power management level: 128
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
* Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Free-fall Control feature set
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* Idle-Unload when NCQ is active
* NCQ priority information
Non-Zero buffer offsets in DMA Setup FIS
* DMA Setup Auto-Activate optimization
Device-initiated interface power management
In-order data delivery
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Write Same (AC2)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
Security:
Master password revision code = 65534
supported
enabled
locked
not frozen
not expired: security count
supported: enhanced erase
Security level high
122min for SECURITY ERASE UNIT. 124min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000cca726c270e9
NAA : 5
IEEE OUI : 000cca
Unique ID : 726c270e9
 Post subject: Re: Hitachi 5K750-500 Password reset?
PostPosted: October 28th, 2017, 1:32
ZU - ATA Password Unlock Tool for Several Drives:
http://www.hddoracle.com/viewtopic.php?f=95&t=166
Users browsing this forum: No registered users and 250 guests
