Fujitsu BlackHook
August 9th, 2017, 3:55
Hi guys
I have a Fujitsu hdd that has come to me in a very bad shape: opened, no front sticker at all and clicking. Of course , some data has to be recovered from him.The big problem is that I don't know what hdd is exactly.
Here are some photos of the hdd:
Now, what I did:
The hdd is clicking softly for some time that it gives RDY but every command returns ABRT.
I have copied the ROM in the programmer , but it looks too empty for me ( maybe I'm wrong).
Fijutsu.rar
(8.85 KiB) Downloaded 516 times
The data inside the ROM is in BigEndian (if I'm not mistaken) but it still looks too empty.
From the PCB number it look like an MHV2160BT hdd but I'm not really sure.The problem is that I have to buy an identical one to exchange heads so I need to know exactly what model of fujitsu is.
What do you think?
Can anyone give me a hint?
Re: Fujitsu BlackHook
August 9th, 2017, 5:01
A little detail: it's a 12mm height case and a 4200rpm motor (is really quiet).
Also , does anyone have a backup ROM from a MHV2xxxBT to try to compare with what I have?
Thanks.
August 9th, 2017, 12:57
i found similar pcb on MHV and MHW drives.
I had MHX2300BT a couple of years ago but the drive is not here anymore and i have not backed up rom :(
This was probably 12mm high, as yours.
August 9th, 2017, 15:11
No, it is probably OK. The dump i have from similar drive is mostly empty as well.
August 9th, 2017, 15:32
Your ROM dump shows ...
    BlackHook-A 0604(C) FUJITSU
Google suggests that the 88i6735A-BAN1 MCU was used in the CA26343-B82104BA and B84204BA PCBs. Yours is the former.
Google also suggests that the CA26343-B82104BA PCB was used in the MHV2200BT and MHV2160BT models (4200 RPM).
The 5400 RPM models (MHW2120BH/MHW2100BH/MHW2080BH/MHW2060BH/MHW2040BH) appear to be associated with the CA26343-B84204BA PCB.
The part number on the spindle motor (CA06596-3762) appears to be associated with the MHV2200BT and MHV2160BT models.
CA06820 appears to be a BH part number.
ISTM that your drive is either an MHV2200BT or MHV2160BT.
August 9th, 2017, 15:53
he said it is 12mm high, so it should be MHX.
August 9th, 2017, 16:05
Google searches suggest that MHX2300BT is associated with the CA26343-B84304BA PCB and a p/n of CA06846. :?
MHV2160BT datasheet:
http://www.fujitsu.com/downloads/COMP/fcpa/hdd/mhv2160bt_datasheet.pdf
Dimensions
Height 12.5 mm (.49 in.)
Width 70 mm (2.8 in.)
Depth 100 mm (3.9 in.)
Weight 135 g (4.76 oz.) or less
August 9th, 2017, 17:07
attached the fw backup of the MHX2300BT I have. Pay attention to module 013A.
edit: it seems it does not mean anything, MHV2160BT has similar number (0604) in 13D...
This was quite different in the rom dump i have for MHV2120BH but i have no SA dump for that rom dump so...
I also saw some MHT2160BT on ebay where it is clearly a 9mm high drive:
http://www.ebay.com/itm/Fujitsu-160GB-S ... SwMmBV6DPl
however specs say 0.49" in most places, so it seems to be quite obscure.
FUJITSU MHX2300BT-0041000B-K205T8528GMV.rar
(336.73 KiB) Downloaded 454 times
August 9th, 2017, 18:08
Would this be a YYYY-MM-DD date stamp, and does it help?
00000000  28 43 29 20 46 55 4A 49 54 53 55 20 2E 2E 2E 2E  (C) FUJITSU ....
00000010  FF FF B0 FF F6 DF 4F 00 00 00 4F 00 00 00 00 00  ÿÿ°ÿößO...O.....
00000020  20 06 11 16 00 00 09 20 00 B8 00 00 47 1B 8F 09   ...... .¸..G...
          2006/11/16
00000030  42 6C 61 63 6B 48 6F 6F 6B 2D 41 20 30 36 30 34  BlackHook-A 0604
MHX2300BT - 2008/01/07
00000010  FF FF F4 FF DB 3F 02 01 41 00 0B 00 00 00 00 00  ÿÿôÿÛ?..A.......
00000020  20 08 01 07 00 00 24 C0 00 B5 00 00 B8 02 3B 2D   .....$À.µ..¸.;-
ROM_swap.rar
(8.51 KiB) Downloaded 593 times
August 10th, 2017, 2:31
Hi
Thanks for reply's
@pepe
When I first saw this drive I was also thinking is a MHX model. But, after searching on Google, I saw that MHX is using another PCB version number.So this is not a MHX probably.
@fzabkar
After intensive searching on Google I have come to the same conclusion, that could be a MHV2xxxBT drive, but I still need a backup ROM from someone to compare with mine.
Also, regarding ROM structure. From Acelab Fujitsu manual, at offset 20h , first 4 bytes should be Firmware version and the next 4 bytes should be (firmware)Version date. It looks like the manual is a bit outdated because in this ROM they look to be inverted.
So, I still need a ROM backup to make an idea about what model to try/buy.
Thanks again.
August 10th, 2017, 3:56
Ordered an MHX2300BT, we'll see what's inside flash...
August 10th, 2017, 8:42
I have a working MHX2300BT here
PCB is CA26343-B84304BA
August 10th, 2017, 16:01
FWIW (maybe nothing?), the ~0105FI.rpm file in the MHX2300BT resource dump contains the text string "0041000BC024". This appears to correlate with the ROM header as follows:
Offset(h) 00   02   04   06   08   0A   0C   0E
00000000  2843 2920 4655 4A49 5453 5520 2E2E 2E2E  (C) FUJITSU ....
00000010  FFFF F4FF DB3F 0201 4100 0B00 0000 0000  ÿÿôÿÛ?..A.......
00000020  2008 0107 0000 24C0 00B5 0000 B802 3B2D   .....$À.µ..¸.;-
The corresponding string for the patient would be "0000004F2009".
00000010  FFFF B0FF F6DF 4F00 0000 4F00 0000 0000  ÿÿ°ÿößO...O.....
00000020  2006 1116 0000 0920 00B8 0000 471B 8F09   ...... .¸..G...
August 11th, 2017, 2:04
Sean
Can you try to make a dump/copy the ROM from your drive just to compare with what I have?
The 0105 module (FI) has Factory Infomation info so I think it is OK to find the same info from ROM in it.
Thanks again guys.
August 23rd, 2017, 8:44
Just received an MHX300BT, attached the rom.
It's problably not the one you have.
MHX2300BT_CA06846-B20100SN_03FE2A-00410000B.zip
(9.13 KiB) Downloaded 491 times
August 23rd, 2017, 18:27
ISTM that the ROMs contain no code, just data (adaptives?).
August 24th, 2017, 3:47
it contains some code too.
August 24th, 2017, 5:16
HI
After comparing the 2 ROM's it looks like this:
Yes, they contains some code and 4 little modules for start-up.
Also, it looks like Fujitsu has changed the offset location for Firmware version, Firmware date, etc in ROM header compared to old models.
So, the MHX ROM has 0041000B firmware version and mine has 0000004f firmware version. Looking here
http://www.donordrives.com/catalogsearc ... =MHV2160BT
it looks like my hdd is indeed a MHV2160BT drive.
So I think that we have enough info to conclude that the drive in a MHV2160BT.
What do you think guys?
August 24th, 2017, 5:44
probably yes.
btw, have you checked if heads are dirty or what's inside?
August 25th, 2017, 2:31
Yes
That was the first thing I've done when it come to me as it was already opened by the client.
It looks ok inside, no dust and the heads are clean.
Rgds
