 Post subject: MICROSOFT SURFACE PRO-SAMSUNG SSD-MZ-FLV2560(PM951)
PostPosted: November 22nd, 2017, 1:31
Microsoft surface pro 4 with (Samsung SSD-MZ-FLV2560(PM951) there is screen is broken partially can see display,also OS is corrupted.always can see there uncompleted windows loading attempt.it means SSD basically its ok.i removed SSD from surface pro installed in desktop M.2 slot built in motherboard. windows cant see SSD but bios is detected SSD even installed SSD Samsung driver no use.again i suspected SSD may damage i put back to surface pro again still it is working like windows need to load but uncompleted.other side i connected surface pro device is connected mini display cable to external HDMI monitor for trying with more attempt.it never show display to external monitor.i buy a docking station for surface pro to try as desktop.even with dock no display usb port is working by dock.anybody can help on this matter.y windows cant see or detect SSD itself?i used SSD to PCI adapter also.
 Post subject: Re: MICROSOFT SURFACE PRO-SAMSUNG SSD-MZ-FLV2560(PM951)
PostPosted: November 22nd, 2017, 2:19
Have a history of 10+ Surface Pro 3/4 recovery's using, I always connect to PC3000 via SATA.
All i have seen had Bit Locker enabled by default, so you might need to ask client to get the recovery key from their microsoft account or domain administrator.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 22nd, 2017, 2:34
HI,
if you have Pc3000 or MRT connect use Converter Msata to Sata you can access it.
it might have bad sectors thats why your OS cant mount properly..
https://www.ebay.com/itm/mSATA-SSD-to-S ... SwnHZYdVPe
https://www.ebay.com/itm/Black-Mini-pci ... Sw44BYDXjs
http://www.lifeguarddatarecovery.com
Report private message
PostPosted: November 22nd, 2017, 3:05
Hi
Thanks for all.
generally it show at least in device manager.i cant see them.
Users browsing this forum: Google [Bot] and 47 guests
