 Post subject: Help me find a matching donor
PostPosted: October 31st, 2017, 17:29
Hello all,
I have recently had some bad luck matching drives and wanted to take the time to ensure the drive I purchase is a match. I am aware that sometimes this is not possible and I have no choice but to take a risk.
The drive that I think is the best possible match is - http://www.donordrives.com/western-digi ... drive.html
If you knowledgeable folks can just confirm this for me would be great. Thanks in advance.
The specs for my drive pulled using PC3K are -
Name.................................... : HHOVJHK
Encode Date............................. : JUN 2012
Model................................... : WD10JMVW
Sub model............................... : 11S5XS0
Country of manufacture.................. : MY
pcb..................................... : A
headsmap................................ : 0,1,2,3
Preamp vendor........................... : 0001
Preamp revision......................... : 0000
MJ0..................................... : F47--119E
MJ1..................................... : FB9--1210
MJ2..................................... : F96--11ED
MJ3..................................... : 1006--125D
ROM..................................... : 0003004A
 Post subject: Re: Help me find a matching donor
PostPosted: November 1st, 2017, 1:33
HI,
Donor is Perfectly Match check the patient Heads in microscope before Swapping Donor Heads to Patient.
may be surface wasnt good what happen you return back Donor Heads to DOnor ? if it didnt work then Media have problem too not just Heads.....
PostPosted: November 1st, 2017, 10:56
I would match the bold and underlined parameters:
DCM: HHOVJHK
Model: WD10JMVW-11S5XS0
I usually go for a manufacture date that's relatively close and older than patient.
Data Recovery Cape Town
PostPosted: November 3rd, 2017, 16:18
Thanks Fellas,
Went ahead and ordered a different one from ebay. Saved me a few dollars.
Users browsing this forum: No registered users and 291 guests
