 Post subject: WD HDD is making Chirping Noise
PostPosted: November 15th, 2017, 21:07
Hello Gurus,
I have a WD 2.5" HDD which is making a chirping sound like a cricket. I opened it up and dont see the head on the platter. What could be the issue?
Just trying to read it once so that I can get my data back. It's not getting detected when I am connecting it with a SATA to USB cable. No scratches on the disks are visible.
 Post subject: Re: WD HDD is making Chirping Noise
PostPosted: November 16th, 2017, 11:46
You need professional data recovery help with this drive. Opening a drive outside of a cleanroom environment will do/has done damage to the drive if spun up again. If you data is valuable, seek professional help.
PostPosted: November 22nd, 2017, 13:38
it's not good to open HDD outside clean room. As ddrecovery said if you data important to you give it to local data recovery professionals
PostPosted: November 24th, 2017, 2:08
Banned User
Do not open hard disk without clean environment if data is imp then go to the professional data recovery.....
PostPosted: November 24th, 2017, 11:01
Sounds like a drive coming from a laptop. Correct? If yes, was the laptop dropped or sustain some sort of physical shock while powered on?
Users browsing this forum: No registered users and 38 guests
