 Post subject: ST380815AS
PostPosted: January 2nd, 2018, 8:52
Hello
The drive in topic is always busy.
I can read sectors by terminal, but very very slow.
Is there any suggestions?
Thanks in advance.
Terminal output:
4096k x 16 DRAM
NHAWK - 1_Disk S-41 10-23-06_16:40
HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 33 RdWr 137dc.00.0003
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 137dc.00.0003
Unable To Load Overlay 01|000A
T>
 Post subject: Re: ST380815AS
PostPosted: January 2nd, 2018, 16:27
Spildit wrote:
ATA overlay is damaged so you can't access the drive by ATA.
APP code is ok as you have level T and not F. Adaptives and Defect lists should be ok.
Try to boot from loader. Maybe you can extract the data if you load the drive by a loader with correct FW version. This should load ATA overlay on RAM.
Also if you have FW for your drive you can try to replace ATA overlay as long as you use correct one.
Or you can try to read ATA overlay from your drive and see if you are lucky ...
Thanks for the input.
I will try with matched loader.
thank you
PostPosted: January 2nd, 2018, 16:44
Er 33 RdWr - not load adаptive UA
PostPosted: January 3rd, 2018, 8:11
Spildit wrote:
Interesting.
Can you try R2 at T> ?
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
T>R2
Code - 74 Track FFFFF(137DC).0.012 Sns FFF Rty 027F.FF.80FF Rtf 1800 LBA 000005E5
T>
PostPosted: January 3rd, 2018, 8:21
Case solved by transferring by terminal. :)
Data needed was some XLS's
Thank you very much. :good:
