 Post subject: Can I recover from chkdsk d: /x /f ?
PostPosted: February 6th, 2018, 17:00
I have an Elements external USB drive that was corrupted. I ran this command to fix it. The problem is it deleted the index entry files I needed. Is there a way to recover the data from these two files below? I have not written to the HD since.
C:\Users\user>chkdsk d: /x /f
The type of the file system is NTFS.
Deleting index entry filename-here.txt in index $I30 of file 452.
Deleting index entry filename-2-here.txt in index $I30 of file 452.
Any suggestions would be greatly appreciated.
Thanks.
S
 Post subject: Re: Can I recover from chkdsk d: /x /f ?
PostPosted: February 6th, 2018, 17:28
Try with Recuva, GetDataBack or R-Studio.
PostPosted: February 6th, 2018, 18:50
I tried Recuva in the past and it didn't bring up the file I'm looking for. Maybe I'll try again with the latest version if R-studio doesn't work.
Currently scanning using R-studio which looks a bit more robust. Should I scan for all files or can I focus in on just the .txt files which I am after?
Since I'm after the data in "$I30 of file 452", how does that translate to the hex editor so I can see the data in that space? Or it doesn't work that way?
Thanks.
S
PostPosted: February 6th, 2018, 23:08
Deleting index entries is a consequence of the problem, not the problem itself.
NTFS has an MFT entry for a file, and then in every directory containing that file (which may be more than one) it will store the index entry. If the file ceases to exist, index entries should be removed. This normally happens as a part of file deletion, but if there is a power failure or somethnig, or if the file is damaged instead of deleted, there is a stale index entry pointing to the file which does not exist any longer. These index entries are cleaned up during checkdisk.
translates into
Deleting index entry (a pointer to) filename-here.txt in index $I30 (normal directory index) of file 452 (of a directory which has MFT ID 452), because the file no longer exists.
You should look earlier in the log to see what happens with the file itself.
PostPosted: February 7th, 2018, 14:09
"You should look earlier in the log to see what happens with the file itself."
There is nothing in the chkdsk log file with this filename before this entry. Just before the lines with the two files I'm trying to recover it displayed the following lines below. $130 matches but the file number is different.:
"Correcting error in index $I30 for file 441.
CHKDSK discovered free space marked as allocated in the bitmap for index $I30 for file 441.
Sorting index $I30 in file 441."
I've finished the scan. There are a bunch of .txt files with numbers for filenames. Is there a way to search for the old file name or contents of these files in R-studio?
Thanks.
S
PostPosted: February 7th, 2018, 14:30
Generally speaking, chkdsk causes irreversible damage and should never be run on a drive that isn't backed up.
PostPosted: February 7th, 2018, 17:02
Now the external drive is not booting and I'm getting a denied error. This is why I originally ran the chkdsk program to begin with so I could access the drive. I'm not going to do the chkdsk again. This occurred on Windows. I switched to the Linux computer and the drive shows up normally again. Now I have to re-install R-studio and run a scan again.
PostPosted: February 7th, 2018, 17:04
This external WD Elements drive was supposed to be the main backup drive. My 2nd backup was a USB flash drive and that died too as well as the original SSD drive in my laptop which died first.
PostPosted: February 7th, 2018, 17:49
First option should be to make a clone and work with that...not with the original drive.
http://www.rescue-it.se
Users browsing this forum: Google [Bot] and 92 guests
