January 19th, 2018, 15:13
Hi!
I have this M.2 drive from Kingston that is not showing any sign of life..
Could someone please help showing me where to do some measurements, trying to troubleshoot what’s wrong.
- Attachments
January 19th, 2018, 16:42
Check the zero-ohm resistor and TVS diode. Then measure voltages V1, V2, and Vnand.
RT8010GQW, Richtek, 1.5MHz, 1A, High Efficiency PWM Step-Down DC/DC Converter, 2.5V to 5.5V input, marking ET, adjustable:
http://www.richtek.com/assets/product_file/RT8010=RT8010A/DS8010A-10.pdf
- Attachments
- Vnand.jpg (59.72 KiB) Viewed 24422 times
- TVS.jpg (117 KiB) Viewed 24422 times
January 21st, 2018, 8:38
Many thanks @fzabkar !
I will check this tonight and see what I can find.
January 21st, 2018, 16:17
The TVS diod shows 0.85Vdc (+ to -) and 0.38Vdc (- to +), thats not right, is it?
All the other voltages is 0.
January 21st, 2018, 16:41
I’m a bit suppressed to se the writing “AC” on it tough, what could that mean?
- Attachments
- 704498F5-718C-47C3-87FD-E4291944C790.jpeg (58.05 KiB) Viewed 24294 times
January 21st, 2018, 16:44
What voltage do you measure on each side of the zero-ohm resistor? Which point are you using as your ground reference?
January 21st, 2018, 16:55
Two possible candidates with different specs ???
TUSD05FB, SPSEMI, TVS diode, 5V, 350W, marking AC, SOD-323:
http://www.spsemi.cn/Upload/pdf/esd/tusd03fb-tusd24fb.pdfUCD32C03L01, BrightKing, TVS diode, 3.3V, 220W, marking AC, SOD-323:
http://www.brightking.com/uploadfiles/file/ESD/u/2017100918551555154200.pdf
January 22nd, 2018, 3:05
fzabkar wrote:What voltage do you measure on each side of the zero-ohm resistor? Which point are you using as your ground reference?
Each side is showing 3.3Vdc.
I used pin 3 as GND measuring voltages.
When I measured the diod, I used both sides on the TVS and the diod function on the Fluke DMM.
January 22nd, 2018, 3:25
The TVS diode is OK. I would now check the Enable pins of each converter IC.
January 22nd, 2018, 3:52
fzabkar wrote:The TVS diode is OK. I would now check the Enable pins of each converter IC.
They are all 0Vdc.
I measure middle pin on both sides, GND and EN
January 22nd, 2018, 4:56
IC "F" looks like a uP reset IC. If so, then its Reset pin should be high.
MAX6328_R29-T, Maxim, 3.3V supply monitor, 2.9V threshold, marking ACV, SC70:
https://datasheets.maximintegrated.com/ ... AX6405.pdfhttp://www.farnell.com/datasheets/76835.pdf
January 22nd, 2018, 10:46
fzabkar wrote:Something is keeping all 3 regulators switched off. Can you identify the markings on the smaller ICs/transistors/supervisors?
Here are some better pictures with the marking on.
- Attachments
- AC-V
January 22nd, 2018, 10:53
It is a reset IC, found it in the farnell pdf as "AVC".
Between pin 1 and 2 there is 0V.
Pin 1 and 3 = 0.69V
January 22nd, 2018, 17:13
I can't identify the VLAN or T3m0J parts, but the others could be ...
SN74LVC1G02, Single 2-Input Positive-NOR Gate, marking CB5, 5-pin, SC70:
http://www.ti.com/lit/ds/symlink/sn74lvc1g02.pdfSN74LVC1G11, Single 3-Input Positive-AND Gate, marking C35, 6-pin: (wrong package?)
http://www.ti.com/lit/ds/symlink/sn74lvc1g11.pdfYour measurements for the ACV part would suggest that I may have incorrectly identified it. Otherwise it is not receiving 3.3V Vcc, which seems strange. In fact, I'm not even sure that the marking is "ACV" (the "A" doesn't look like an "A").
I would try to find the IC which is driving the Enable pins of the regulators, then work backwards from there. Just test for continuity between Enable and each of the ICs.
- Attachments
- MAX6328_pinout.gif (10.44 KiB) Viewed 24110 times
January 22nd, 2018, 22:47
Sometimes you can find images of the drive online, and look at what is in the same place as the "AC-V" part. Sometimes they substitute it with a different number and you can ID that one and at least know its function. If it is a critical part of analysis here..
January 23rd, 2018, 15:02
HaQue wrote:Sometimes you can find images of the drive online, and look at what is in the same place as the "AC-V" part. Sometimes they substitute it with a different number and you can ID that one and at least know its function.
Good idea. Unfortunately I could find only one site with hi-res images.
http://www.ocfreaks.com/kingston-m-2-sata-sm2280s3-120gb-ssd-review/http://i.imgur.com/JNlzEBY.jpghttp://i.imgur.com/VInsdcP.jpghttp://i.imgur.com/JNlzEBY.jpgThe other PCB uses the same "AC-V" part. :-(
The OP's "T3m0J" part is equivalent to "T3n0M", so it would appear that "T3" is the device code and the remaining characters are probably batch or date codes.
The "VLAN" part is equivalent to "f4R".
Unfortunately I can't identify the alternative parts, either. :-(
January 23rd, 2018, 16:34
I should add that the TVS diode's rating is 5V (marking = 5C).
ESDA05CT, Congshuo Electronic Technology, TVS diode, bidirectional, 5V, 100W, marking 5C, SOD-523:
http://cssemi.cn/upfile/201601/2016010660039309.pdfAQ4021-01FTG-C, Littelfuse, Congshuo Electronic Technology, TVS diode, bidirectional, 5V, 500W, marking 5C, SOD-323:
http://www.littelfuse.com/~/media/electronics/datasheets/tvs_diode_arrays/littelfuse_tvs_diode_array_aq4021_datasheet.pdf.pdf
January 23rd, 2018, 16:41
Thanks allot for all your inputs!
I've done some measurements. The 0,69V, could that be valid or is something pulling it down?
- Attachments
