 Post subject: Strange Behaviour WD10EARS
PostPosted: March 25th, 2018, 12:27
The patient hsa bad head 2. used Donor, drive doesn't ID with DONOR. but PATIENT HEAD can ID in DONOR.
Patient Head works in both - DONOR N PATIENT
But DONOR head works in only DONOR, Doesn't work at PATIENT
Have you ever faced such issue?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Strange Behaviour WD10EARS
PostPosted: March 25th, 2018, 13:35
Sir
Please Block SA ,Disable All Heads But 0 ,Put PCB to HDA ,Run Does It Work Now " After Loader + Dir Module Loading To Ram " . If yes enable all other heads follow procedure again does it work now .If you have micro jogs active in this or preamp try to average them out and then try
PostPosted: March 25th, 2018, 13:43
Did you try another donor?
PostPosted: March 27th, 2018, 16:16
No, didn't try 2nd donor due to scarcity of Donor
__________
THANK YOU
SHAHI
