 Post subject: WDC WD5000AAKX-00ERMA0
PostPosted: January 1st, 2018, 12:38
Hello
Need Ldr and full resources for the drive in topic.
0002000C
Thanks in advance
 Post subject: Re: WDC WD5000AAKX-00ERMA0
PostPosted: January 1st, 2018, 13:07
I have this version but is in pcr format......try it.
http://www54.zippyshare.com/v/G6hgcVmE/file.html
PostPosted: January 2nd, 2018, 9:52
The problem that I don't have UDMA. (using MRT ultra)
I can't extract the pcr file.
Thank you very much anyway.
PostPosted: January 2nd, 2018, 10:23
MRT program can extract files from pcr file.....
PostPosted: January 2nd, 2018, 10:25
MRT common tools-->Data managment tools-->Tools--> Import resources
PostPosted: January 2nd, 2018, 10:28
How is that, please?
PostPosted: January 2nd, 2018, 10:30
Thank you very much :good:
PostPosted: January 2nd, 2018, 16:25
Spildit wrote:
Or .... use this :
https://disk-on.ru/pcr
(File size limit 50 Mb)
:D :D :D
Thank you.
Case already solved. :good:
PostPosted: January 2nd, 2018, 16:37
Spildit wrote:
Or .... use this :
:D :D :D
Sorry,this site is not work anymore...
ERROR:
Server error in the application '/'.
We could not find this resource.
Description: HTTP 404. It is possible that the resource (or one of its dependent components) was deleted, received a different name, or temporarily unavailable. Review the following URL and verify that it is entered correctly.
Requested URL: / Home / error
PostPosted: January 2nd, 2018, 17:13
Works fine for me. Looks like the OP may be blocked.
PostPosted: January 2nd, 2018, 17:29
Ошибка сервера в приложении '/'.
Не удалось найти данный ресурс.
Описание: HTTP 404. Возможно, искомый ресурс (или один из зависимых от него компонентов) удален, получил другое имя или временно недоступен. Просмотрите следующий URL-адрес и проверьте, что он введен правильно.
Запрошенный URL: /Home/error
PostPosted: January 2nd, 2018, 17:33
Just tried it with an 8mb file and it converted to zip fine. Does the OP have the correct ZIP program?
PostPosted: January 2nd, 2018, 17:38
I had tried several times with different browsers, without success. Now I tried again and was successful. PCR file size was 6MB.
PostPosted: March 26th, 2018, 7:40
Guys, if you have problems with disk-on.ru - please, write to me at skype yustik74.
this online version is very old and have few problems, i have new offline version with non-limit unpacker, we can always to extract any file manually
PCR extracting. Remote data recovery from DVR. Skype: yustik74
Users browsing this forum: No registered users and 93 guests
