 Post subject: ST3500418AS CC34 Firmware Update Problem
PostPosted: April 7th, 2018, 12:21
Disk shows up 0 Mb on win7 and 8 mb on XP.
smart value is invisible.
F3 T>
Rst 0x10M
ASCII Diag mode
F3 T>i4,1,22
F3 T>m0,6,3,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewr
ite Retries = 2DF8
Init SMART Fail
LED:000000CC FAddr:0024EAA9
Rst 0x10M
Rst 0x10M
F3 T>V40
DiagError 00005002
Invalid Diag Cmd Parameter
F3 T>/1
F3 1>N1
Init SMART Fail
solution is here ..
http://www.hpwlab.com/hdd-en/thread-456-1-1.html
but i can not update firmware to CC49
CC49.exe and CC49.iso via DVD don't work. it says model matches but firmware not matches.
but offical seagate site says it's very important updating to CC49.
is there any way to update firmware? or how can i find .Lod file?
 Post subject: Re: ST3500418AS CC34 Firmware Update Problem
PostPosted: April 7th, 2018, 12:55
You could force the firmware update, but I believe that wouldn´t solve your problem, and could make things worse.
PostPosted: April 7th, 2018, 15:15
The LOD files can be extracted from the ISO or EXE. Just use 7Zip.
Users browsing this forum: Google [Bot] and 28 guests
