 Post subject: ST2000LM007 - Terminal Diag - SMART Reset
PostPosted: April 7th, 2018, 16:51
I'm hoping that a kind soul with more expertise than I might throw me an assist. I'm no expert, but believe I should be able to manage resetting SMART on a Seagate ST2000LM007. I picked up a PL2303HX USB-TTL RS232 Arduino off eBay, but am having difficulties with getting terminal T>. Based on my research, the pin config for the diag port should be:
___________________
| Pwr | GND | TX | RX | - |SATA| - |PWR|
So, I've connected my pins accordingly; using 38400 8N1 None with Realterm, and have played around with multiple pin configs. I just can't seem to get to T> no matter what. About the best I'll manage is either a locked session that is unresponsive, or depending on the config it will spit a bunch of garbled data (in ascii- hex will display characters).
Wondering if my usb-ttl is junk, or rather inappropriate for this job.
Prolific USB-TTL pin scheme
- Red: + 5V
- Black: Ground
- Green: RXD
- White: TXD
Hoping someone can steer me towards the right config with the hardware I have, or steer me towards what I need to purchase. I have 2 Seagate drives (ST2000LM003 & ST2000LM007) that I'd like to reset SMART on. I've tried to include the pertinent information in the pics.
Thank you so much!
 Post subject: Re: ST2000LM007 - Terminal Diag - SMART Reset
PostPosted: April 7th, 2018, 17:01
Well, the first the point is why do you want to reset smart in the hdds ? What are the problem in them that you are trying to solve. The correct procedures depend somewhat on the problem.
Also, your ttl adapter will not work. You need a lower voltage compliant one, so easier to get one based in the CP2104 chip.
PostPosted: April 7th, 2018, 17:19
Add that terminal acces is blocked and needs to be dealt with.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: April 7th, 2018, 17:40
Your feedback is super helpful; thank you. The issue with this specific drive is that I lost power during a Secure ATA erase. From that point, SMART was tripped and the drive rendered inoperable. However, I believe the drive itself is perfectly fine.
I attempted using the Seachest cli tools to no avail, so this seemed the next logical step. I'll start by picking up a CP2104 chip. However, with respect to the "terminal access blocked" issue.... is there workaround?
Thanks again for your assistance.
PostPosted: April 7th, 2018, 17:58
Thank you very much for the feedback. I'll assume that something like this https://www.ebay.com/itm/CP2102-CP2104-USB-to-Serial-Adapter-Module-w-6-Jumper-Wires/181088668352?epid=1531823743&hash=item2a29b9cac0:g:ofoAAOSw8b1Z~MSJ will do the trick.
I feel like an idiot, but to save time- I was performing a Secure ATA Erase on 2 drives at the same time; a ST2000LM003 & ST2000LM007 and suffered a power outage. Both drives were rendered inoperable, but should be mechanically perfectly fine, other than the SMART was tripped on both. I'm not in "the business", but am technically inclined. I've just have never delved this deep into drive recovery stuff before. I appreciate your willing to point me in the right direction.
Are there any known workarounds for the "block" on terminal for these Rosewood drives?
Thanks again.
PostPosted: April 7th, 2018, 19:13
The problem you see probably is not from smart, but due to the drives being locked with password before the secure erase and that password not having been removed.
Try to redo the erase, with the same tool and password as before. Maybe this will solve your problem.
PostPosted: April 8th, 2018, 9:30
Well, it is possible.
But the OP didn´t post SMART logs, or elaborate on the problem. So we don´t know exactly what he means by it, same as we do not know why he wanted to do a secure erase of them at first.
PostPosted: April 8th, 2018, 15:29
Okay, so please bear in mind that I am unable to get to terminal on this drive, at the moment. The tools that I am using are within the SeaChest git, which offers Windows and Linux binaries. If there is a better way for me to access SMART logs... I am all ears. But, here is what I have (and the process that I've used).
**A couple important aspects to take note of. Please notice: "SMART Status: Tripped & ATA Security Information: Supported." I believe that I've been able to clear the password from the previous Secure ATA Erase, in a previous attempt. As I understand it, if it were locked due to password... that field would say: "Supported, Frozen".
Notes: BIOS recognizes drive. Linux & Windows recognize the drive. In Windows, Disk Management will prompt me to Initialize the Disk, and to give it a partition table MBR/GPT. Selecting either options gives me "Data Error (cylic redundancy check)". If I dd directly to write the fail, bombs out with failures.
Here is a log:
<Drive Information>
<Command> seachest_basics -d PD1 -i
\\.\PhysicalDrive1 - BUP Slim - 2HC015KJ - ATA
        Model Number: BUP Slim
        Serial Number: 2HC015KJ
        Firmware Revision: 0304
        World Wide Name: 5000C5009BF838CC
        Drive Capacity (PB/PiB): 144.12/128.00
        Temperature Data:
                Current Temperature (C): Not Reported
                Highest Temperature (C): Not Reported
                Lowest Temperature (C): Not Reported
        Power On Time: Not Reported
        Power On Hours: Not Reported
        MaxLBA: 281474976710653
        Native MaxLBA: Not Reported
        Logical Sector Size (B): 512
        Physical Sector Size (B): 512
        Sector Alignment: 0
        Rotation Rate (RPM): 7200
        Form Factor (inch): Not Reported
        Last DST information:
                Not supported
        Interface speed:
                Max Speed (Gb/s): 6.0
                Negotiated Speed (Gb/s): Not Reported
        Annualized Workload Rate (TB/yr): Not Reported
        Total Bytes Read (B): Not Reported
        Total Bytes Written (B): Not Reported
        Encryption Support: Not Supported
        Cache Size (MiB): Not Reported
        Read Look-Ahead: Enabled
        Write Cache: Enabled
        Low Current Spinup: Disabled
        Firmware Download Support: Full, Segmented
        Specifications Supported:
                ATA8-ACS
                ATA/ATAPI-7
                ATA/ATAPI-6
                ATA/ATAPI-5
                ATA/ATAPI-4
                SATA 3.0
        Features Supported:
                SATA NCQ
                SATA Software Settings Preservation
                SATA Device Initiated Power Management
                HPA
                Power Management
                Security
                SMART [Enabled]
                DCO
                48bit Address
                GPL
                Write-Read-Verify
                EPC [Enabled]
                SCT Write Same
                SCT Error Recovery Control
                SCT Feature Control
                SCT Data Tables
<Does the drive respond to 'Ready'>
<Command> seachest_basics -d PD1 -s
\\.\PhysicalDrive1 - BUP Slim -  - ATA
READY
<Disable ATA Security Password from previous attempt>
<Command> SeaChest_Erase --device PD1 --disableATASecurityPW user
Security Feature is not enabled. Nothing to do.
Successfully disabled ATA security password!
<Attempt Secure ATA Erase>
SeaChest_Erase -d PD1 normal --confirm I-understand-this-command-will-erase-all-data-on-the-drive
Secure Erase
Setting ATA Security password to "SeaChest"
Failed to set ATA Security Password. Cannot erase drive.
<Attempt to see SMART Attributes>
<Command >SeaChest_Info -d PD1  --smartAttributes raw
Error retreiving the logs.
A failure occured while trying to get SMART attributes
<Another direct SMART Check>
<Command>SeaChest_SMART -d PD1 --smartCheck
SMART Check
SMART has been tripped!
<Attempt to disable SMART altogether>
<Command>SeaChest_SMART -d PD1 --smartFeature disable
A failure occurred while trying to configure SMART feature
PostPosted: April 8th, 2018, 15:38
Quick note... I generated those logs plugged in as USB (which is why it's reporting BUP Slim). However, plugged into SATA... it is a ST2000LM007 with a different firmware listed. The end result is the same for the tests / logs, but per the request- I quickly "re-did" these logs on USB for the purpose of this conversation.
PostPosted: April 8th, 2018, 15:41
I don't know this forum didn't post my previous reply, but here are the logs that I am able to produce. Bear in mind that I don't have terminal, so the best tool that I am aware of is the Seachest git.
Notes: BIOS recognizes drive. Windows recognizes drive. Disk Management prompts me to Initialize the Disk, and to give it a partition table MBR/GPT. Selecting either options gives me "Data Error (cylic redundancy check)".
**A couple important aspects to take note of. Please notice: "SMART Status: Tripped & ATA Security Information: Supported." I believe that I've been able to clear the password with the Secure ATA Erase, in a previous attempt. As I understand it, if it were locked due to password... that field would say: "Supported, Frozen".
<Drive Information>
Temperature Data:
Sector Alignment: 0
Not supported
Interface speed:
ATA8-ACS
ATA/ATAPI-7
ATA/ATAPI-6
ATA/ATAPI-5
ATA/ATAPI-4
SATA 3.0
Features Supported:
SATA NCQ
HPA
Power Management
Security
SMART [Enabled]
DCO
48bit Address
GPL
Write-Read-Verify
EPC [Enabled]
SCT Write Same
SCT Feature Control
SCT Data Tables
READY
Secure Erase
SMART Check
PostPosted: April 8th, 2018, 16:14
I did better than that, but it's awaiting moderator approval for some reason.
PostPosted: April 8th, 2018, 17:06
Since it appears I can make short quick posts, I'll just say. Tools like Victoria / HDD Scan, etc- don't offer anything of value. The only tools that I seem to make headway with are the SeaChest toolset. And, my (albeit) inexperienced opinion is... SMART reset is what is needed. BIOS shows: SMART: Capable, but command fails. I have to use a Seachest tool to get Windows to recognize the drive. I'm not sure if you've used them, but highly recommended for cli hd troubleshooting.
PostPosted: April 8th, 2018, 17:23
Now you speak English
you're trying to promote something?!
That could also mean that you cannot access the smart information due to the locked situation of the drive.
Your first post was long and with pictures attached, and it got through ok. Maybe something different in the way you built your post with the SMART reports ?
Try to use the Code tags and put the SMART information inside them.
PostPosted: April 8th, 2018, 17:31
Promoting nothing more than the fact that Seagate's tools work better for Seagate drives; which should be obvious. And, that I'm under the impression they are rather new, so many people many not be aware of their existence.
And, thank you Rogfanther. That is what I did. I hope soon mod approves the post.
PostPosted: April 9th, 2018, 7:09
If you look further up the thread, you'll see what I was able to produce using Seachest.
PostPosted: April 9th, 2018, 11:17
Please, post the information from Victoria or MHDD with the drive connected to SATA.
Also, try with MHDD to set a password, then run secure erase.
Users browsing this forum: No registered users and 97 guests
