 Post subject: How I can repair wd busy error
PostPosted: April 13th, 2018, 15:40
lf wd hdd take wrong firmware and become busy
and no response when I do power reset to save new firmware
How I can repair it
 Post subject: Re: How I can repair wd busy error
PostPosted: April 13th, 2018, 16:02
How I can repair it
Too vague,what did you actually do?
PostPosted: April 13th, 2018, 16:17
How I can repair it
PostPosted: April 13th, 2018, 16:19
Spildit wrote:
Do you need the data from the drive ?
What do you mean by taking wrong firmware ? Did you write wrong modules to platter or wrong ROM to PCB ?
Do you need the data from the drive ?No
What do you mean by taking wrong firmware ? Did you write wrong modules to platter or wrong ROM to PCB?Yeah
PostPosted: April 13th, 2018, 16:35
Mosaad2018 wrote:
How I can repair it
Repeat the same vague and question and expect answer?
PostPosted: April 13th, 2018, 16:46
Did you back up original firmware?
https://www.mjm.co.uk/
PostPosted: April 13th, 2018, 16:50
Yeah
PostPosted: April 13th, 2018, 16:56
Please answer these questions as accurately as you can.
1. Did you over write the original ROM?
2. If yes how did you write it?
3. Did you over write any of the System Area with new firmware?
4. If so how did you write it to the drive?
5. Do you have a copy of original ROM?
6. Do you have a copy of the original SA Firmware?
7. Why did you over write firmware in the first place.
PostPosted: April 13th, 2018, 17:04
Spildit wrote:
Yeah !
:roll: :roll: :roll:
Well, at least his Boolean logic is correct.
                              __
  wrong modules to platter  --\  \
                               |  |-- wrong firmware to somewhere
          wrong ROM to PCB  --/__/
PostPosted: April 13th, 2018, 17:26
Spildit wrote:
Yeah !
                              __
wrong ROM to PCB :good: :good: :good: :good:
Users browsing this forum: Google [Bot] and 63 guests
