 Post subject: WD30EFRX-68AX9N0 strange problem (for me)
PostPosted: April 25th, 2018, 15:14
when connected, the disc rotates for a few seconds then stops, then rotates again and so on.
I have had similar cases before that were solved with a change of pcb, but this particular case leaves me with no options.......
patient disc + pcb donor + patient rom ----> same result (spin up/down constantly) ------> discard pcb problems
patient disc +pcb donor + rom donor ---> same result ----> discard corrupt rom problems
Isolated head contacts ---> same result ---> would rule out preamplifier or head problems
Am I missing something??
motor damage???.... but it would be the first case I see in this series and even less when it turns (not blocked).
Has anyone ever had this happen to you? And most importantly, what was the solution?? :D
 Post subject: Re: WD30EFRX-68AX9N0 strange problem (for me)
PostPosted: April 25th, 2018, 15:28
How does a working drive behave when you isolate its HDA?
PostPosted: April 25th, 2018, 15:56
hello fzabkar, your opinions are always welcome, thank you
I know, it doesn't make sense, but it does exactly the same thing, it turns and stops turning after a few seconds, turns again, stops again........
It's haunted!!!!!!!
PostPosted: April 25th, 2018, 16:15
It appears that the firmware is designed to spin up the drive and then check the preamp, in which case ISTM that the preamp/headstack must be faulty.
You might like to compare the resistances between ground and each of the preamp supply test points (+5V & -5V). You could also measure the voltages at the HDA contacts, eg the read channel test points (TV9 & TV10).
PostPosted: April 25th, 2018, 16:24
In WD the usual is the opposite, first check the preamp and then spin up, that's why I discarded preamp or head problems, but as I don't believe in witches, I'll do the checks.
Thank you fzabkar
PostPosted: April 25th, 2018, 17:09
Spildit wrote:
I would vote for damaged pre-amp / head(s).
Yes, it is most reasonable, PCB and Rom are discarded and the motor is very unlikely, there are few options,
What I don't understand is the reason for the continuous spin attempts,
That’s what it is.
Users browsing this forum: Google [Bot] and 90 guests
