 Post subject: Ldr & Ram for Maxtor DiamondMax Plus 45
PostPosted: January 11th, 2005, 8:29
Does anyone have the Ldr & Ram for the drive listed below? If so, would it be possible for me to get a copy of them. Thanks for any and all help in getting this.
Jennifer
Model: 53073H4
HDA: 04A
PCBA: 03A
Unique: 11A
Firmware Code: JAC61HU0
Drive Capacity: 30 GB
RPM: 7200
ATA Drive
 Post subject:
PostPosted: January 11th, 2005, 11:30
First, you would like this files to use with what ?
The same utility that permits you to use this files will get the same files from a good drive.
Second, to your record only:
There is 2 kinds of processors in har disks Maxtors ( new models ) that can be used byt the PC3000. One is the Poker and the Other is the DSP, and of course that in poker processors you can also use the variant. But in all cases I do not saw this model.
So could you tell us what you are thinking ?
PC-MXPKR utility - models that are suported:
6Y160L0, 6Y120L0, 6Y080L0, 6Y060L0, 6E040L0, 6E030L0, 6E020L0, 2F040L0, 2F030L0, 2F020L0, 2B020H1, 2B015H1, 2B010H1, 4D080H4, 4D060H3, 4D040H2,
PC-MXDSP utility - models that are suported:
2B020H1, 2B015H1, 2B010H1, 2R015H1, 2R010H1, 4D080H4, 4D060H3, 4D040H2, 34098H4, 33073H3, 32049H2, 31535H2, 1024H1
Users browsing this forum: Google [Bot] and 83 guests
