 Post subject: WD3200BMVV-11A1CS0 Donor search
PostPosted: June 20th, 2018, 9:38
Hi Sirs,
I'm trying to search in my inventory a donor for USB drive WD3200BMVV-11A1CS0 DCM:HACTJBBB, head map 0 2 3, so also 500Gb drives could be good.
Other than perfect match (not found), what SATA/USB drive model/family can be compatible?
Thanks a lot in advance
Max
 Post subject: Re: WD3200BMVV-11A1CS0 Donor search
PostPosted: June 20th, 2018, 10:11
Any Mariner with 4 heads should work.
Search for SATA interface drives with PCB # 771672
Good luck
PostPosted: June 20th, 2018, 11:26
I will search for it. Thanks, good luck to you too.
PostPosted: June 20th, 2018, 12:28
Good luck
I agree 85%
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: June 21st, 2018, 0:58
Dear hamidbid,
do you have other suggestions? They are welcome!
Thanks, Max
Users browsing this forum: No registered users and 239 guests
