 Post subject: WD 250GB Zone allocation table Error ( Pinnacle )
PostPosted: July 20th, 2018, 14:35
I got a 2010 WD 250GB blue WD2500AAJS that comes up with error Zone allocation table : Error and 0GB Capacity.
Drive spins up 2 twice very short 4- 5 seconds and spins down very slight click ( 2 in total ) I replaced the reading heads and same issues. Old heads work in donor surprise there.
Any idea what else to try or do. DDI comes up as 0 capacity too.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 1
Head map : .....................................: 0
SA Cyl Count : .................................: 170
Serials Mark : .................................: 0xCB16
Control version : ..............................: 46A1
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 192 Kb
ROM version : ..................................: 05.FME
ROM generation : ...............................: 05.FME
Link table version : ...........................: 04.0K
ROM Firmware version : .........................: 000500FM
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x1
heads map : ....................................: 1
 Post subject: Re: WD 250GB Zone allocation table Error ( Pinnacle )
PostPosted: July 20th, 2018, 14:38
Sorry I had one head deactivated:
RAM:
Heads number : .................................: 2
Head map : .....................................: 3
ROM:
ROM Modules:
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
PostPosted: July 20th, 2018, 15:55
Update. A hot pcb swap seems to work drive is reading and writing acceptable.
Users browsing this forum: No registered users and 77 guests
