 Post subject: ST31500541AS show as unallocated with 3.86GB
PostPosted: August 5th, 2018, 9:33
My Seagate HDD stop working & show as unallocated with 3.86GB.
After my diagnostic when i plug the disk in the power support of computer, the disk motor works but after some seconds i heard knocks .. after 7 or 8 knocks the motor disk stop.
 Post subject: Re: ST31500541AS show as unallocated with 3.86GB
PostPosted: August 5th, 2018, 9:47
Can you post terminal log?
Unfortunately, typical symptoms of head/s failure.
PostPosted: August 5th, 2018, 9:50
likely heads are gone
Data Recovery Pakistan
PostPosted: August 5th, 2018, 10:03
how can i make a terminal log ??
PostPosted: August 5th, 2018, 10:04
if i changed the heads, the drive will works again ??
PostPosted: August 5th, 2018, 10:38
Maybe, but it all depends of the data in the drive. If it the data is not worth some US$ 200 or 300 at least, then just get another drive
PostPosted: August 5th, 2018, 10:39
Thank you
PostPosted: August 5th, 2018, 12:06
After that the motor stops, does it start to spin again after few seconds or it stay stationary?
If motor starts to spin again without re-plugging power supply, then it might be a firmware issue, this can happen often in particular 7200.11 seagate drives as ST3750330AS or ST31000333AS models.
But if you have any other seagate family or even a common 7200.11 drive as ST3500320AS model, then motor will not spin up again automatically and this means that heads are faulty.
My firmware database:
PostPosted: August 5th, 2018, 12:33
I forgot to say, also your ST31500541AS (Barracuda LP) drive can behave by re-starting the motor if there is a firmware issue.
If motor doesn't spin alone again, then definitely it has bad heads.
Users browsing this forum: Google [Bot] and 220 guests
