 Post subject: HDD Seagate - tripartioned now shows only one unpartitioned
PostPosted: August 22nd, 2018, 11:35
Hello, I am quite in trouble about one main HDD tripartioned as ext4, NTFS and HFS+.
Each partition was bootable, managed by the GRUB system.
At first the Chamaleon Bootloader failed starting the MacOs partition, then after I reinstalled the boot1h in my Mac partition (/dev/sda1, whole HDD is /dev/sda), as expected I got a Boot0 error... But when I booted from a live Ubuntu dvd, with surprise I noticed all different partitions were lost now turned into unallocated space.
My idea is to run an application like get data back to retrieve my files, however I don't know if it will be enough due to the three different filesystem on my Disk.
Thanks in advance for any suggestions.
 Post subject: Re: HDD Seagate - tripartioned now shows only one unpartitio
PostPosted: August 22nd, 2018, 16:57
Can you show us the Partitions window in DMDE? Depending on the problem, there may be a simple DIY fix.
https://dmde.com/
PostPosted: August 23rd, 2018, 5:52
Thank you very much, I read it only now and this program seems indeed what I was looking for.
Luckily I tried with a Ubuntu live dvd (I'm not much into windows OS) and testdisk was able to fix the tables
Now the disk is ready for r/w and apparently every data is in place.
Now I'm trying to repair the boot part and see if I can run my OSs back.
About this, again, every suggestion will be very welcome.
Thank you so much again
