 Post subject: Question about Kahuna hybrid hard drive
PostPosted: September 10th, 2018, 19:40
I have a customer who submitted a ST500LM000 that had stuck heads. After head swap, was able to image around 25% of the drive and then it quit responding. I think that there is a problem with the onboard cache and would like to swap PCBs w/ ROM transfer to test. My question is, does running IO from terminal on the donor drive accomplish the same thing as performing a secure erase? It seems both methods work to clear the cache, but wanted to get everyone's input.
 Post subject: Re: Question about Kahuna hybrid hard drive
PostPosted: September 11th, 2018, 1:29
Issuing I from level O will erase flash and init ALF tables, so its not the same as secure erase.
When you say quit responding what do you mean? You did a head swap, so if heads where bad in the beginning i would look there again, terminal should also give you some hints.
To change PCBs on these you might need to adapt donor ROM, use ACE labs solution or disable NAND.
Digitalsupport Data Recovery
https://digitalsupport.dk
