ST2000LM007
September 11th, 2018, 10:15
The drive in topic takes about 30 sec to be ready with full model, capacity, fw and sn. Then all sectors shows unc.
Terminal output:
Boot 0x80M
Rst 0x80M
Srv DETCR init 0x000
(P) SATA Reset
RAW OFF
PASS
EDAC Value = 00000000FFFFF844
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
No Phy: Staggered spin bypass
DSC
ASCII Diag mode
F3 T>
Thanks in advance.
Re: ST2000LM007
September 11th, 2018, 11:09
I have backed up all HDD resources except F****N sysfile 348 because it is damaged.
I had a case like this before and I didn't solve it because the customer took the drive next day.
viewtopic.php?f=1&t=37076
Any ideas?
Re: ST2000LM007
September 11th, 2018, 12:25
there is a way to fix it... :) without messing up with the drive.
Re: ST2000LM007
September 12th, 2018, 10:36
@ MindMergepk,
Many thanks
The man solved the issue in 5 seconds
