 Post subject: WD10JMVW-11AJGS3 not ready
PostPosted: September 24th, 2018, 18:37
Ok I have this drive that I have diagnosed it has the slow response problem. And it will show up as "not ready" on Windows, or cannot initialize in OSX. So I assume it is on "busy" mode.
The thing: I do not have fancy software such as PC3K or so. Is it possible to solve this without it? So to access modules I will need to convert the PCB to a SATA if I am correct.
Thanks in advance
 Post subject: Re: WD10JMVW-11AJGS3 not ready
PostPosted: September 24th, 2018, 19:01
EDIT:
I could use the SATA conversion and Marvel WD tool to access SA right? but then swap to USB PCB in order to decrypt? after sorting the modules I mean.
It will need a new head assembly for sure.
PostPosted: September 25th, 2018, 15:00
Possibly if you can patch some firmware parameters and get access to the disk, then it is very possible that you have problems with a head.
PostPosted: October 2nd, 2018, 1:47
Spildit wrote:
Are you willing to pay for a recovery ? Because if it's going to need clean room work it's not a do-it-yourself thing ...
I have a vertical laminar flow bench, already replaced heads
The thing is that I am still learning with firmware issues, and that I cant afford a PC3000 and that makes drives me nuts
PostPosted: October 2nd, 2018, 6:45
Do you have any tools to work with firmware ?.
The WDMarvell is quite economical
Indicate if you use something for firmware and it will be easier to help you.
Greetings.
PostPosted: October 2nd, 2018, 6:56
Greetings.
Thanks for the reply.
No I haven't got any firmware tools but I did look into WDMarvell. It seems that now it supports the USB PCB Board?
Cheers
PostPosted: October 2nd, 2018, 8:42
It is effectively compatible with USB.
Although I prefer to convert them to SATA, we do not avoid an additional hardware / software layer.
You can start with the demo version to do tests with any WD disk that you do not need.
Users browsing this forum: No registered users and 212 guests
