 Post subject: hdt721010sla360 clicking
PostPosted: October 12th, 2018, 15:33
hello guys, I have an old Hdd, it seems that haunt me :-) a hitachi 1tb 2008 october hdt721010sla360 that after the spin makes a click. Connected to MRT is not detected under any circumstances. According to you are the heads?
Startup Mode...................................... : Diagnosis Mode
WARNING! Failed to obtain the hard disk ID information. It may caused by the following reasons:
1. Incorrect compiler module.
2. NV-RAM configuration is incorrect.
Selected family:HDx7210SL
Model:
Loading TeachKey.................................. : Error
WARNING! Failed to read Flash ROM. It may caused by the following reasons:
1. PCB board failure.
2. Flash ROM chip damage.
 Post subject: Re: hdt721010sla360 clicking
PostPosted: October 13th, 2018, 4:50
Spildit wrote:
I would get a working drive of the same model and try ! Does MRT read modules/nvram from a drive of the exact same model ? If so the problem is indeed with the drive and not with MRT
+1
I think that it is a good working method to assume that the tools can give errors for certain HDD models.
PostPosted: October 13th, 2018, 8:46
Yes it's a great idea.
Users browsing this forum: Majestic-12 [Bot] and 34 guests
