 Post subject: Leaving power cable in
PostPosted: November 15th, 2018, 3:37
Hi, want to know if it is "Ok" to leave the SATA power cable in my hard disk while just removing the DATA cable from my hard disk. I want to disconnect my hard disk from the motherboard but i only want to remove the data cable is that ok?
Motherboard(power IN, data IN)<---------->(power IN, data plugged OUT) Hard disk
 Post subject: Re: Leaving power cable in
PostPosted: November 15th, 2018, 9:53
Spildit wrote:
Depends of what you are doing ....
Might not be the safest thing to do as the system might be writing data on the drive when you uplug the sata cable. It would be as bad as removing power + sata.
If you are careful not to touch the components and short stuff yes, removing just the sata cable is "safe" as long as the system is not accessing the drive...
I think u got confused with my question, i am removing the DATA cable only when my PC is completely shut down. Just want to know if when i power up my PC with ONLY the power cable attached to the MB<--->Harddisk. Will it cause any issue? Data cable is un-attached.
PostPosted: November 15th, 2018, 10:11
No, that won't cause any issue. The drive will just power up and sit there waiting for a computer to initiate communication (which won't happen).
PostPosted: November 15th, 2018, 10:15
Ok, thank you so much for the reply :D
Users browsing this forum: ccc, Google [Bot], pepe and 58 guests
