ST1000LM035-1RK172 FW:- SBM3
November 3rd, 2018, 4:26
hi,
i have problem with this seagate HDD rosewood
Boot 0x80M
Rst 0x80MSrv DETCR init 0x0000
EDAC Value = 0000F018E59FF018
DOS:0 Scan Unit
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
Overlay PartNum: 08102038
CFW PartNum: 12041940
Overlay CompileDate: 20160810
CFW CompileDate: 20161204
OverlayCompatibilityCheck failed
any one have solution for this please help.
Re: ST1000LM035-1RK172 FW:- SBM3
November 3rd, 2018, 4:30
can we check via Teamviewer ?
November 7th, 2018, 16:44
I guess this drive did not get into this state just by itself, so what's the story?
November 7th, 2018, 16:56
ISTM that the OP is using an incompatible donor ROM after transferring the patient's adaptives to it ??? Or could this be the result of an interrupted firmware update?
November 8th, 2018, 0:13
I bet someone wrote foreign modules and diag overlays' version mismatch
November 11th, 2018, 4:55
fzabkar wrote:ISTM that the OP is using an incompatible donor ROM after transferring the patient's adaptives to it ??? Or could this be the result of an interrupted firmware update?
Hi
look like others tried it.
November 11th, 2018, 5:09
absolutely correct, The ROM has been tempered.
November 11th, 2018, 15:54
i knew it was tampered, but the story is still useful when thinking about the solution
