 Post subject: Hitachi HDS721010DLE630 - HEAD 1 SLOW READ
PostPosted: December 20th, 2018, 2:39
I have this HDD and I can read the SA without problems the 2 copies of the SA.
The HDD is initialized very well and enters RDY quickly.
The problem is that to read 8 sectors of the user zone of the head 1 takes almost 2 seconds, but the SA reads it well at the same speed head 1 and 0. No reading errors of the SA.
The HDD comes unopened and for the moment I discard the change of heads.
Any ideas?
Thanks in advance.
 Post subject: Re: Hitachi HDS721010DLE630 - HEAD 1 SLOW READ
PostPosted: December 20th, 2018, 16:18
thanks for the tips.
The process in the background and the relocation will not be disabled in hitachi.
All data from head 0 are saved. I tested by IOP and reverse copy but without results.
It is almost certainly the head but I wanted to try before making the change.
PostPosted: December 20th, 2018, 19:02
it seems that I do not express myself well, I use the google translator.
I do not know, for HDD hitachi disable relocation and background.
PostPosted: December 30th, 2018, 18:54
Thanks for the indications. I do not have the HRT.
At the moment the client does not tell me if he wants to recover the HDD.
If you confirm the recovery I will comment.
Greetings and happy ending and beginning of the year.
PostPosted: December 30th, 2018, 19:50
mhp666 wrote:
Also if you do get stuck with firmware fixes maybe you can outsource some of those drives to me !!! It will be better than ending up in the garbage bin ...
I have it in mind, we are not far away and I believe that postage can be economical.
The important thing is to give solutions.
Users browsing this forum: Google [Bot] and 63 guests
