 Post subject: Trying to recover partiton(files) from 6.4gb quantum firebal
PostPosted: December 23rd, 2018, 17:01
quantum fireball AEXA OD50 EX series
I know that the disk is old, but i hope someone with more knowledge will help me or share a light on some ideas on what to do
So what happened the disk was working and than the partition went missing so far i tried w/o luck lot's of recovery programs even managed to create an image from the drive(but cause the data is from unpartitioned disk-corrupted disk i am unable to find a single file).
so my question is
Can i use parts from SE series quantum fireball 6.4
actuator pcb etc...
Just to note disk is not found in
HDAT2, Spinrite
But it shows in bios and when logged in windows or any linux
This is my first post , i have knowledge but i still learn :)
 Post subject: Re: Trying to recover partiton(files) from 6.4gb quantum fir
PostPosted: December 23rd, 2018, 21:51
First don't even think about using parts and opening the drive up.
-Never used parts but was considering it - drive was opened after scaning with testdisk(used to work before).
If you can still see the drive in windows and linux with full capacity and if you did manage to image it it's better for now not starting messing it up more.
-Drive is seen in windows and linux with full capacity tho partition is missing
Start by checking the image file or clone with hex editor. Can you see any "data" at all or you can see only random garbage or zeros ?
-Image file has a random garpage of zeros.
Did you check if the drive can be addressed by LBA or does it support C/H/S only ?
-I need to research how to do this.
Did you ear any strange noise from the drive like clicking ? Can you clone the drive with something like hddsuperclone ?
-I can try cloning, yes there was old click of death sound
Can you see the drive with MHDD ? And on BIOS does the drive ID with correct capacity ?
-No MHDD HDAT2 SPINRITE do not see the drive at all.
If you can detect the drive with MHDD you might want to try to scan it just some LBAs to see if you do have access to them ...
-I will do another try with MHDD, i thing there's only DOS version am i right ?
Are you willing to pay some money for data recovery ?
-Timeframe is small so shipping it and waiting is not an option, i also don't know if this can be fixed remotely(almost sure it won't work)
If the data is of importance to you you better start looking for a reputable data recovery firm as the more you mess with the drive the more are the chances that you do make the data un-recoverable !!!
-Data is important but as i said it will take week or two to write everything again cause there's backup from past month
Do not open the drive up without a laminar flow workbench and even less without even knowing what is going on with the drive !!!
-It was click of death https://www.youtube.com/watch?v=UmTFVuEXzwk that is not my video :P
Do you have some firmware tool to work with Quantum ? Did you bother to check terminal output of the drive using TTL ?
-I could test everything and do as suggested if i am told what to do.
Are you willing to pay at least something to get the data recovered ?
-If there's remote option but i don't think it will work sorry for not being so optimistic about remote :)
and sorry for my english
PostPosted: December 24th, 2018, 18:32
I think you have about 3 options:
1) Take the drive to a reputable data recovery specialist. But it seems you are reluctant to do this.
2) Try to image the drive with HDDSuperClone, and then try to recover files from the image. If that fails, then see option #1.
3) If you dont't want to do option #1, and option #2 doesn't work, then accept that the data is gone.
EDIT
I missed this first part:
Considering you opened the drive, SEE OPTION #1! Or accept option #3.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: December 24th, 2018, 19:59
EDIT
I wanted to tell that few years back same thing happened i used test disk and it found the partition and recovered the drive. I did backup and told my friend to do backup every week or so or order a new drive. Apparently he did not listen!
Data is somewhat important either type the whole thing for 2 3 weeks or fix it in next 4 5 days.
The disk was running everyday since 1998. ;)
If it where some ultra mega hellish important data in there i would have stopped on first click of death, that i heard at his office.
I recovered almost all of his data from backups.
I do admit i don't understand the Head swap for quantum drives , and i also did not try or perform one i was just considering it cause it was like this try everything if nothing works than we type.
About remote support i thought just to check for scientific purposes.
Users browsing this forum: No registered users and 76 guests
