 Post subject: FW Request - WDC WD5000AAKS-00V1A0 0011003M
PostPosted: September 9th, 2020, 14:29
Hi.
I request firmware 0011003M for WDC drive WD5000AAKS-00V1A0.
There is one on the hddguru servers, but it is in PCR format.
https://files.hddguru.com/index.php?action=view&filename=WDC%20WD5000AAKS-00V1A0%2005.01D05%20WD-WMAWF1483167.rar&directory=PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Tahoe&
Thank you
 Post subject: Re: FW Request - WDC WD5000AAKS-00V1A0 0011003M
PostPosted: September 9th, 2020, 15:20
DeVlL wrote:
Hi.
Thank you
HDDSurgery has it in their FW database. You get one download a day for free.
PostPosted: September 9th, 2020, 16:21
ddrecovery wrote:
DeVlL wrote:
Hi.
Thank you
Hi.
I had already downloaded this firmware from hddsurgery, before posting this thread.
WD5000AAKS-00V1A0-05-01D05-WD-WMAWF1348170
But it has version 11003G.
It loads modules 01 and 02 well in RAM, loads the ID with its model and serial number correctly, but the capacity loads it badly. Mark 233GB when it should be 500GB.
Then I test acensial modules and I get bad 03, 11 and 33 copy 0. From copy 1 I get all the bad modules. From the composite copy he reads them but with errors.
IF I test all the modules of the copy 0 I get many bad modules.
So I wanted to try another firmware of the same version to compare.
Thank you so much
PostPosted: September 9th, 2020, 16:26
DeVlL wrote:
ddrecovery wrote:
DeVlL wrote:
Hi.
Thank you
Hi.
Thank you so much
I think you downloaded the wrong one.
If you enter 0011003M in the search box you will find 4 matches.
PostPosted: September 9th, 2020, 17:01
ddrecovery wrote:
DeVlL wrote:
ddrecovery wrote:
DeVlL wrote:
Hi.
Thank you
Hi.
Thank you so much
If 4 matches come out.
We discard the first one because it is for a WD1600AAJS-00V4A0
The others are:
WD5000AAKS-75V0A0
WD5000AAKS-65V0A0
WD5000AAKS-65V0A0
Wouldn't they have to match my unit which is WD5000AAKS-00V1A0 to be compatible?
So they are 00V1A0.
Thanks for your help.
PostPosted: September 9th, 2020, 18:51
Ideally they should be from the same family yes.
Yours is a Tahoe PL and those are a Tahoe, you may as well try.
PostPosted: September 10th, 2020, 5:24
I will try to try all 3. Thanks
PostPosted: September 10th, 2020, 6:52
MRT can unzip PCR.
PostPosted: September 10th, 2020, 11:06
colanco wrote:
MRT can unzip PCR.
Well you're right, I didn't know that MRT could open these PC3000 files.
Thank you so much
PostPosted: January 19th, 2021, 18:32
ddrecovery wrote:
DeVlL wrote:
Hi.
Thank you
5 you get 5 for free.
We must pay to Mr Bezos every download, but we will make it 10 soon.
HddSurgery - Professional Data Recovery Tools
Users browsing this forum: No registered users and 40 guests
