Help with bringing USB HDD to life? [WD5000LMVW - 11CKRS0]
August 10th, 2020, 5:32
[Oh no, another noob asking for help :roll: ]
Anyways, Hello!
Im sure youre all here more pro˙s than I am noob, but hope you˙ll find a bit time of yours to at least try to help me.
Okay, so I got this 500GB WD USB HDD some time (years) ago. But drive then started behaving as follows:
1. Plugged in,
2. Drive spinup,
3. Reading something a bit, (no "bad" sounds, only healthy, working HDD clicking noises),
4. Spinoff,
5. Go to sleep and do not wake until power cycled.
Whole it took like 10 secs, nothing showing up of course, not even sound of new recogized PnP device.
So I thought PCB issue! Ordered one, swapped both EEPROMs aaand, nothing. I did it some time ago, so I dont remeber what happened and whatnot but it definitely wasnt working. (I think HDD didnt even spin up it was just chillin there like it wasnt suposed to do anything).
I was desperate. And dumb (okay, im still dumb). So I did what I thought was sensible idea.... OMG Im embarrased.... I mixed and matched the EEPROM Chips. (not the position like they have different footprint). It achieved one thing although I still dont know if its good or bad sign: Drive now shows up...
As... "WD My Passport 07AE USB, MBR, 0,50KB :lol: "
So... yeah that˙s the current state, hoping someone knows what to do try next.
Here I am some time later, and with enough free time around decided to poke at it again.
BUT, fear not, because I˙m not ordinary "Save my data" noob, I˙m an UltraNoob™! Just - I have some basic understanding of Disk drives, physical as well as logical, also, I have a decent soldering skills, hot air reflow, and EEPROOM programmer, so I can even dump those EEPROOMs here if anyone of you could make some sense of it (I was looking at the sea of FF˙s for a few minutes now, and it didn˙t help me in any way yet :lol: )
I˙m sure there will be a TON of things and terminologies I won˙t understand, but I˙ll just ask, no shame...
Thank You!
Re: Help with bringing USB HDD to life? [WD5000LMVW - 11CKRS
August 10th, 2020, 13:30
Here are the dumps of the EEPROOMS:
EEPROOM.rar
EEPROOMs
(558.52 KiB) Downloaded 438 times
August 10th, 2020, 19:00
The first ROM (U12) is from a 500GB drive, the second from a 250GB.
Analysing WINBOND_W25X20_SOIC.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A 2B   02     100 -  22A5      12000     21A4  21A4  68DF 68DF   OK
   20  01 A6   0C    22A6 -  435A   A0800000     20B4  20B4    19   19   OK
   40  02 A5   01    435B -  CDF7          0 c   B3FC  8A9C    5B   5B   OK
   60  03 A5   01    CDF8 -  D434      10FAC c    78C   63C    B3   B3   OK
   80  04 75   03    D435 -  D655      80220 c    2EC   220    C5   C5   OK
   A0  05 CF   03    D656 -  D84A   10148A08 c    2F0   1F4    49   49   OK
   C0  06 6D   01    D84B - 2538F   900CDE00 c  1F748 17B44    2D   2D   OK
   E0  07 A9   01   25390 - 3CB78   90002630 c  20FF8 177E8    65   65   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
ROYL directory module 0x000B found at 0x3F090
Active directory flag = 0x01
Identifying SA regions ...
Reg#  Reg size    Reg loc
0x00  0x0002B50B  0x00000000
0x01  0x0002B50B  0x00059D00
Verifying ROYL modules ...
ID          Size (bytes)         Address    Checksum
dir   hdr    dir       hdr
0001  N/A    00004000  N/A        0000F471             N/A
000A  OK     0000003E  00000200   0003D3C2   00000000  OK
000B  OK     00000169  00000200   0003F090   00000000  OK
020B  OK     00000169  00000200   0003E090   00000000  OK
0030  OK     00000400  OK         0003D400   00000000  OK
0047  OK     00000400  OK         0003DC00   00000000  OK
000D  OK     00000090  00000200   0003F000   00000000  OK
004F  OK     00000400  OK         0003D800   00000000  OK
ROYL directory module 0x020B found at 0x3E090
Active directory flag = 0x00
0x02  0x0002B50B  0x000B3A00
0x03  0x00000000  0x00000000
0x04  0x00000000  0x00000000
0x05  0x00000000  0x00000000
0x06  0x00000000  0x00000000
0x07  0x00000000  0x00000000
dir   hdr    dir       hdr
0001  N/A    00004000  N/A        00000000             N/A
000D  OK     00000090  00000200   0003E000   00000000  OK
dir  -  Module ID/Size as reported in directory module (0x20B or 0x0B)
hdr  -  Module ID/Size as reported in module's header
N/A  -  Not Applicable
BAD  -  Module has invalid checksum. This may be due to non-existent module.
ROM modules saved to Flash_00\000Bmods and Flash_00\020Bmods
Active directory is 0x0B
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 2/2
Head map #1 = 0x03 / 0b00000011
Head map #2 = 0x00 / 0b00000000
DCM = | N | 1 S K J D 1 S
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : bottom VCM
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Analysing active 0x0D module ...
Firmware Version = 01.01A01
World Wide Name = 50014EE25CD67686
Model Number = WDC WD5000LMVW-11CKRS0
Serial Number =
Analysing active 0x4F module ...
ROM version = 0002004C
Analysing active 0x47 module ...
Preamp values
0  032E3611
1  012B140C
2  02200400
3  02200400
4  02200400
5  02200400
Microjogs
0  116B
1  0FE9
2  0A0A
3  0A0A
4  0A0A
5  0A0A
Head/Media DCM = KS
Analysing UNKNOWN_SOIC_A25L020_possibly_original.bin ...
    0  5A 43   02     100 -  22B1      12000     21B0  21B0  FC98 FC98   OK
   20  01 22   0C    22B2 -  439E   A0800000     20EC  20EC    80   80   OK
   40  02 26   01    439F -  CE4F          0 c   B410  8AB0    6B   6B   OK
   60  03 32   01    CE50 -  D49C      10FAC c    7A0   64C    58   58   OK
   80  04 DD   03    D49D -  D6BD      80220 c    2EC   220    53   53   OK
   A0  05 37   03    D6BE -  D8B2   10148A08 c    2F0   1F4    F1   F1   OK
   C0  06 5C   01    D8B3 - 2563B   900CDE00 c  1FA40 17D88    1B   1B   OK
   E0  07 97   01   2563C - 3CF90   90002630 c  21258 17954    9A   9A   OK
Att    = Attributes
dir   hdr    dir       hdr
0x01  0x0002B50B  0x0002CE80
dir   hdr    dir       hdr
0001  N/A    00004000  N/A        0001AD95             N/A
ROM modules saved to Flash_01\000Bmods and Flash_01\020Bmods
Active directory is 0x20B
Number of heads (physical / in use) = 2/1
Head map #1 = 0x01 / 0b00000001
DCM = | N | 1 Z R K H 1 S
      : : : : : : : ACA
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
World Wide Name = 50014EE2076952E6
Model Number = WDC WD2500LMVW-11CKRS0
Serial Number =
ROM version = 0002005R
Preamp values
0  03323419
1  05303415
2  02200400
3  02200400
4  02200400
5  02200400
Microjogs
0  1139
1  10DD
2  0A0A
3  0A0A
4  0A0A
5  0A0A
Head/Media DCM = RZ
August 10th, 2020, 20:34
The two bridge firmwares differ in several places.
These are the headers:
WINBOND_W25X20.bin (USB VID / PID = 1058 / 10A2)
Offset(h) 00   02   04   06   08   0A   0C   0E
00000000  4551 4457 5758 3631 4139 3258 3132 3437  EQDWWX61A92X1247
00000010  2020 2020 2020 2020 0300 0009 1058 10A2          .....X.¢
00000020  180C 0000 3160 373A 0000 0000 0000 0000  ....1`7:........
00000030  0000 0000 1201 4457 0000 0900 0300 0000  ......DW........
00000040  0000 0000 0060 373A 0000 0000 0000 0000  .....`7:........
00000050  0000 0000 1201 4457 EEEE EEEE EEEE EEEE  ......DWîîîîîîîî
00000060  EEEE EEEE EEEE EEEE EEEE EEEE EEEE EEEE  îîîîîîîîîîîîîîîî
00000070  EEEE EEEE EEEE EEEE EEEE EEEE EEEE EEEE  îîîîîîîîîîîîîîîî
00000080  EEEE EEEE EEEE EEEE 2201 4457 0000 0000  îîîîîîîî".DW....
00000090  0000 0000 0100 0000 E44F 574F FFFF FFFF  ........äOWOÿÿÿÿ
AMIC_A25L020_possibly_original.bin (USB VID / PID = 1058 / 07AE)
00000010  2020 2020 2020 2020 0000 000D 1058 07AE          .....X.®
00000020  180C 0000 3060 383A 0000 0000 0000 0000  ....0`8:........
00000040  0000 0000 0060 383A 0000 0000 0000 0000  .....`8:........
00000090  0000 0000 0100 0000 E84F 5E3F FFFF FFFF  ........èO^?ÿÿÿÿ
AFAICT, 10A2 is the PID for a WD Elements.
My Passport would be encrypted, Elements is not.
August 11th, 2020, 10:39
Okay, so both those WINBONDs seems to be the original, so I marked the possibly originals completely other way around :lol: well, nevermind, lets just say I marked "originals" as those on the replacement PCB...
Anyways, it still doesn´t work... ...At the time I was writing this...
But, then I figured, I don´t need content of those other EEPROOMs (for passport) anyways and I had 2 boards of which I didnt know which one is working and which one is broken.
And the other 2 flash were same sizes anyways so I overwrote them with the correct memory content for my HDD, from corresponding winbond EEPROOMs.
So now I had 2 PCBs, on one apparentely original winbond EEPROOMs, on the second other two EEPROOMs with now identical memory content, didn´t know which one worked. The one with the winbond has not worked so I just tried the other one, and...
It right up showed in system, loaded partitions, and all data appear to be fully readable, I have no idea what´s going on.... But it works!
The NTFS had some filesystem errors, checkdisk handled that, and now I´m doing surface test, just in case something shows up, and then off with the data!
Only thing I haven´t figured out is why?. Why it hasn´t worked and why it works with copied EEPROOMs? I don´t know, but perhaps some of you might know...
OF course, not to forget BIG THANKS to fzabkar! I would not be here with (for) now working drive here without his help! I very much appreceiate that dump analysis!
August 12th, 2020, 7:15
you may want to backup that data asap.
August 12th, 2020, 8:27
HaQue wrote:you may want to backup that data asap.
Of course, that already done!
