 Post subject: [Help]Repair the data on 2.5 inches of hard disks
PostPosted: January 15th, 2005, 5:39
I'm from China...
1, Toshiba MK6021GAS, 60GB;
2, Can't recognize record , is it have newspaper " equipment that can't be discerned " under system to receive with usb box , show unknown usb in the management of the equipment, if it is successful to start normally, show MK6021GAS;
3, There is movement sound of magnetic heads after being set up an electric circuit in the hard disk, most situations are slight that the motor started, but has not rotated obviously normally, the voice of the appears sometimes, as if sound that bump into, few time normal sound nearly, work the systematic newspaper " connects the mistake of the hardware " for a moment after starting normally;
4, Different and loud, most time is slight that the motor started, the sound of the appears sometimes, as if the sound that strikes.
Note: A main district, a expanding area, expand the logic district with one 40G in the district, have important data invite 30G above, form NTFS, main district expand district surplus 10G has not been formatted .
PostPosted: January 15th, 2005, 7:53
IMHO this hard disk need to be open, you can try and maybe you can learn soemthing.
After all how you will learn ? I do not think that you would like to buy another hard disk ( new ) to open it and to learn, would you ?
Because here , this is our procedure, we buy another hard disk and we work in it, and later we work in the client's disk.
Users browsing this forum: No registered users and 281 guests
