 Post subject: wd40nmzw spin and immediatly stop
PostPosted: January 22nd, 2019, 12:32
Hi guys, I have a 4 TB USB WD model wd40nmzw that presents this problem: as soon as the disk is connected, it runs for a few seconds and stops, no noise the heads do not move. I then took a sata card to connect it to mrt, as soon as I connect it the disk does not spin while if I put the firmware back on the donor pcb the disk runs and emits the usual head noises that do not align. I then copied the contents of the original rom and flashed it on the pcb donor, nothing to do the disk does not spin and goes in reset continuously. I think Rom is corrupt, partly because I see strange characters edit within winhex. What do you advise me to do?In attachment the original rom thanks to all the original pcb is 2060-800041-003 rev p1 I have change with sata pcb number 2060-800022-000 rev p2
wd_cliente.rar [310.82 KiB]
Downloaded 580 times
 Post subject: Re: wd40nmzw spin and immediatly stop
PostPosted: January 22nd, 2019, 13:05
Out of curiosity can you indicate the numbering of the ROM chip that carries the PCB of this HDD?
PostPosted: January 22nd, 2019, 13:06
mhp666 wrote:
86/5000
only 1
PostPosted: January 22nd, 2019, 13:11
Sorry I use the Google translator and some things I write are not understood.
I refer to the reference of the ROM chip.
PostPosted: January 22nd, 2019, 13:24
winbond 25q40bwv1g on sata board and is25wq040 on usb pcb
PostPosted: January 22nd, 2019, 14:05
You have passed a bin file of 8 MBytes and if I'm not mistaken, that is 4 MBits (512kBytes).
You can check?
PostPosted: January 22nd, 2019, 15:06
you have right, I think it's a bad chip identification of my chip programmer, but when i put the original chip rom on pcb i see the same problem, no spin and continuous reset
PostPosted: January 22nd, 2019, 15:08
Spildit wrote:
Analysing wd_cliente.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A 40   04     140 -  1ED7      4B688     1D94  1D94   000BAF5B unknown CRC
   20  01 11   11    1ED8 -  5F7C   30080000 c   5500  40A4    69   69   OK
   40  02 58   0C    5F7D -  6345   24000000      3C8   3C8    05   05   OK
   60  03 01   40    6346 -  BFAA   FFE00200     5C64  5C64    19   19   OK
   80  04 31   01    BFAB - 120F3          0 c   7C40  6148    49   49   OK
   A0  05 9E   01   120F4 - 12518       DFB0 c    4EC   424    F3   F3   OK
   C0  06 94   03   12519 - 14AA5      402E0 c   3020  258C    44   44   OK
   E0  07 ED   03   14AA6 - 14E7E   602B3400 c    9C0   3D8    3D   3D   OK
  100  08 F6   01   14E7F - 2BBDB   383A4A00 c  1EA30 16D5C    95   95   OK
  120  09 3B   01   2BBDC - 4E48C   38008230 c  2F44C 228B0    85   85   OK
80000  5A 40   04   80140 - 81ED7      4B688     1D94  1D94   000BAF5B unknown CRC
80020  01 11   11   81ED8 - 85F7C   30080000 c   5500  40A4    69   69   OK
80040  02 58   0C   85F7D - 86345   24000000      3C8   3C8    05   05   OK
80060  03 01   40   86346 - 8BFAA   FFE00200     5C64  5C64    19   19   OK
80080  04 31   01   8BFAB - 920F3          0 c   7C40  6148    49   49   OK
800A0  05 9E   01   920F4 - 92518       DFB0 c    4EC   424    F3   F3   OK
800C0  06 94   03   92519 - 94AA5      402E0 c   3020  258C    44   44   OK
800E0  07 ED   03   94AA6 - 94E7E   602B3400 c    9C0   3D8    3D   3D   OK
80100  08 F6   01   94E7F - ABBDB   383A4A00 c  1EA30 16D5C    95   95   OK
80120  09 3B   01   ABBDC - CE48C   38008230 c  2F44C 228B0    85   85   OK
10000  5A 40   04   10014 - 101ED      4B688     1D94  1D94   000BAF5B unknown CRC
10002  01 11   11   101ED - 105F7   30080000 c   5500  40A4    69   69   OK
10004  02 58   0C   105F7 - 10634   24000000      3C8   3C8    05   05   OK
10006  03 01   40   10634 - 10BFA   FFE00200     5C64  5C64    19   19   OK
10008  04 31   01   10BFA - 1120F          0 c   7C40  6148    49   49   OK
1000A  05 9E   01   1120F - 11251       DFB0 c    4EC   424    F3   F3   OK
1000C  06 94   03   11251 - 114AA      402E0 c   3020  258C    44   44   OK
1000E  07 ED   03   114AA - 114E7   602B3400 c    9C0   3D8    3D   3D   OK
10010  08 F6   01   114E7 - 12BBD   383A4A00 c  1EA30 16D5C    95   95   OK
10012  09 3B   01   12BBD - 14E48   38008230 c  2F44C 228B0    85   85   OK
18000  5A 40   04   18014 - 181ED      4B688     1D94  1D94   000BAF5B unknown CRC
18002  01 11   11   181ED - 185F7   30080000 c   5500  40A4    69   69   OK
18004  02 58   0C   185F7 - 18634   24000000      3C8   3C8    05   05   OK
18006  03 01   40   18634 - 18BFA   FFE00200     5C64  5C64    19   19   OK
18008  04 31   01   18BFA - 1920F          0 c   7C40  6148    49   49   OK
1800A  05 9E   01   1920F - 19251       DFB0 c    4EC   424    F3   F3   OK
1800C  06 94   03   19251 - 194AA      402E0 c   3020  258C    44   44   OK
1800E  07 ED   03   194AA - 194E7   602B3400 c    9C0   3D8    3D   3D   OK
18010  08 F6   01   194E7 - 1ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
18012  09 3B   01   1ABBD - 1CE48   38008230 c  2F44C 228B0    85   85   OK
20000  5A 40   04   20014 - 201ED      4B688     1D94  1D94   000BAF5B unknown CRC
20002  01 11   11   201ED - 205F7   30080000 c   5500  40A4    69   69   OK
20004  02 58   0C   205F7 - 20634   24000000      3C8   3C8    05   05   OK
20006  03 01   40   20634 - 20BFA   FFE00200     5C64  5C64    19   19   OK
20008  04 31   01   20BFA - 2120F          0 c   7C40  6148    49   49   OK
2000A  05 9E   01   2120F - 21251       DFB0 c    4EC   424    F3   F3   OK
2000C  06 94   03   21251 - 214AA      402E0 c   3020  258C    44   44   OK
2000E  07 ED   03   214AA - 214E7   602B3400 c    9C0   3D8    3D   3D   OK
20010  08 F6   01   214E7 - 22BBD   383A4A00 c  1EA30 16D5C    95   95   OK
20012  09 3B   01   22BBD - 24E48   38008230 c  2F44C 228B0    85   85   OK
28000  5A 40   04   28014 - 281ED      4B688     1D94  1D94   000BAF5B unknown CRC
28002  01 11   11   281ED - 285F7   30080000 c   5500  40A4    69   69   OK
28004  02 58   0C   285F7 - 28634   24000000      3C8   3C8    05   05   OK
28006  03 01   40   28634 - 28BFA   FFE00200     5C64  5C64    19   19   OK
28008  04 31   01   28BFA - 2920F          0 c   7C40  6148    49   49   OK
2800A  05 9E   01   2920F - 29251       DFB0 c    4EC   424    F3   F3   OK
2800C  06 94   03   29251 - 294AA      402E0 c   3020  258C    44   44   OK
2800E  07 ED   03   294AA - 294E7   602B3400 c    9C0   3D8    3D   3D   OK
28010  08 F6   01   294E7 - 2ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
28012  09 3B   01   2ABBD - 2CE48   38008230 c  2F44C 228B0    85   85   OK
30000  5A 40   04   30014 - 301ED      4B688     1D94  1D94   000BAF5B unknown CRC
30002  01 11   11   301ED - 305F7   30080000 c   5500  40A4    69   69   OK
30004  02 58   0C   305F7 - 30634   24000000      3C8   3C8    05   05   OK
30006  03 01   40   30634 - 30BFA   FFE00200     5C64  5C64    19   19   OK
30008  04 31   01   30BFA - 3120F          0 c   7C40  6148    49   49   OK
3000A  05 9E   01   3120F - 31251       DFB0 c    4EC   424    F3   F3   OK
3000C  06 94   03   31251 - 314AA      402E0 c   3020  258C    44   44   OK
3000E  07 ED   03   314AA - 314E7   602B3400 c    9C0   3D8    3D   3D   OK
30010  08 F6   01   314E7 - 32BBD   383A4A00 c  1EA30 16D5C    95   95   OK
30012  09 3B   01   32BBD - 34E48   38008230 c  2F44C 228B0    85   85   OK
38000  5A 40   04   38014 - 381ED      4B688     1D94  1D94   000BAF5B unknown CRC
38002  01 11   11   381ED - 385F7   30080000 c   5500  40A4    69   69   OK
38004  02 58   0C   385F7 - 38634   24000000      3C8   3C8    05   05   OK
38006  03 01   40   38634 - 38BFA   FFE00200     5C64  5C64    19   19   OK
38008  04 31   01   38BFA - 3920F          0 c   7C40  6148    49   49   OK
3800A  05 9E   01   3920F - 39251       DFB0 c    4EC   424    F3   F3   OK
3800C  06 94   03   39251 - 394AA      402E0 c   3020  258C    44   44   OK
3800E  07 ED   03   394AA - 394E7   602B3400 c    9C0   3D8    3D   3D   OK
38010  08 F6   01   394E7 - 3ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
38012  09 3B   01   3ABBD - 3CE48   38008230 c  2F44C 228B0    85   85   OK
40000  5A 40   04   40014 - 401ED      4B688     1D94  1D94   000BAF5B unknown CRC
40002  01 11   11   401ED - 405F7   30080000 c   5500  40A4    69   69   OK
40004  02 58   0C   405F7 - 40634   24000000      3C8   3C8    05   05   OK
40006  03 01   40   40634 - 40BFA   FFE00200     5C64  5C64    19   19   OK
40008  04 31   01   40BFA - 4120F          0 c   7C40  6148    49   49   OK
4000A  05 9E   01   4120F - 41251       DFB0 c    4EC   424    F3   F3   OK
4000C  06 94   03   41251 - 414AA      402E0 c   3020  258C    44   44   OK
4000E  07 ED   03   414AA - 414E7   602B3400 c    9C0   3D8    3D   3D   OK
40010  08 F6   01   414E7 - 42BBD   383A4A00 c  1EA30 16D5C    95   95   OK
40012  09 3B   01   42BBD - 44E48   38008230 c  2F44C 228B0    85   85   OK
48000  5A 40   04   48014 - 481ED      4B688     1D94  1D94   000BAF5B unknown CRC
48002  01 11   11   481ED - 485F7   30080000 c   5500  40A4    69   69   OK
48004  02 58   0C   485F7 - 48634   24000000      3C8   3C8    05   05   OK
48006  03 01   40   48634 - 48BFA   FFE00200     5C64  5C64    19   19   OK
48008  04 31   01   48BFA - 4920F          0 c   7C40  6148    49   49   OK
4800A  05 9E   01   4920F - 49251       DFB0 c    4EC   424    F3   F3   OK
4800C  06 94   03   49251 - 494AA      402E0 c   3020  258C    44   44   OK
4800E  07 ED   03   494AA - 494E7   602B3400 c    9C0   3D8    3D   3D   OK
48010  08 F6   01   494E7 - 4ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
48012  09 3B   01   4ABBD - 4CE48   38008230 c  2F44C 228B0    85   85   OK
50000  5A 40   04   50014 - 501ED      4B688     1D94  1D94   000BAF5B unknown CRC
50002  01 11   11   501ED - 505F7   30080000 c   5500  40A4    69   69   OK
50004  02 58   0C   505F7 - 50634   24000000      3C8   3C8    05   05   OK
50006  03 01   40   50634 - 50BFA   FFE00200     5C64  5C64    19   19   OK
50008  04 31   01   50BFA - 5120F          0 c   7C40  6148    49   49   OK
5000A  05 9E   01   5120F - 51251       DFB0 c    4EC   424    F3   F3   OK
5000C  06 94   03   51251 - 514AA      402E0 c   3020  258C    44   44   OK
5000E  07 ED   03   514AA - 514E7   602B3400 c    9C0   3D8    3D   3D   OK
50010  08 F6   01   514E7 - 52BBD   383A4A00 c  1EA30 16D5C    95   95   OK
50012  09 3B   01   52BBD - 54E48   38008230 c  2F44C 228B0    85   85   OK
58000  5A 40   04   58014 - 581ED      4B688     1D94  1D94   000BAF5B unknown CRC
58002  01 11   11   581ED - 585F7   30080000 c   5500  40A4    69   69   OK
58004  02 58   0C   585F7 - 58634   24000000      3C8   3C8    05   05   OK
58006  03 01   40   58634 - 58BFA   FFE00200     5C64  5C64    19   19   OK
58008  04 31   01   58BFA - 5920F          0 c   7C40  6148    49   49   OK
5800A  05 9E   01   5920F - 59251       DFB0 c    4EC   424    F3   F3   OK
5800C  06 94   03   59251 - 594AA      402E0 c   3020  258C    44   44   OK
5800E  07 ED   03   594AA - 594E7   602B3400 c    9C0   3D8    3D   3D   OK
58010  08 F6   01   594E7 - 5ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
58012  09 3B   01   5ABBD - 5CE48   38008230 c  2F44C 228B0    85   85   OK
60000  5A 40   04   60014 - 601ED      4B688     1D94  1D94   000BAF5B unknown CRC
60002  01 11   11   601ED - 605F7   30080000 c   5500  40A4    69   69   OK
60004  02 58   0C   605F7 - 60634   24000000      3C8   3C8    05   05   OK
60006  03 01   40   60634 - 60BFA   FFE00200     5C64  5C64    19   19   OK
60008  04 31   01   60BFA - 6120F          0 c   7C40  6148    49   49   OK
6000A  05 9E   01   6120F - 61251       DFB0 c    4EC   424    F3   F3   OK
6000C  06 94   03   61251 - 614AA      402E0 c   3020  258C    44   44   OK
6000E  07 ED   03   614AA - 614E7   602B3400 c    9C0   3D8    3D   3D   OK
60010  08 F6   01   614E7 - 62BBD   383A4A00 c  1EA30 16D5C    95   95   OK
60012  09 3B   01   62BBD - 64E48   38008230 c  2F44C 228B0    85   85   OK
68000  5A 40   04   68014 - 681ED      4B688     1D94  1D94   000BAF5B unknown CRC
68002  01 11   11   681ED - 685F7   30080000 c   5500  40A4    69   69   OK
68004  02 58   0C   685F7 - 68634   24000000      3C8   3C8    05   05   OK
68006  03 01   40   68634 - 68BFA   FFE00200     5C64  5C64    19   19   OK
68008  04 31   01   68BFA - 6920F          0 c   7C40  6148    49   49   OK
6800A  05 9E   01   6920F - 69251       DFB0 c    4EC   424    F3   F3   OK
6800C  06 94   03   69251 - 694AA      402E0 c   3020  258C    44   44   OK
6800E  07 ED   03   694AA - 694E7   602B3400 c    9C0   3D8    3D   3D   OK
68010  08 F6   01   694E7 - 6ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
68012  09 3B   01   6ABBD - 6CE48   38008230 c  2F44C 228B0    85   85   OK
70000  5A 40   04   70014 - 701ED      4B688     1D94  1D94   000BAF5B unknown CRC
70002  01 11   11   701ED - 705F7   30080000 c   5500  40A4    69   69   OK
70004  02 58   0C   705F7 - 70634   24000000      3C8   3C8    05   05   OK
70006  03 01   40   70634 - 70BFA   FFE00200     5C64  5C64    19   19   OK
70008  04 31   01   70BFA - 7120F          0 c   7C40  6148    49   49   OK
7000A  05 9E   01   7120F - 71251       DFB0 c    4EC   424    F3   F3   OK
7000C  06 94   03   71251 - 714AA      402E0 c   3020  258C    44   44   OK
7000E  07 ED   03   714AA - 714E7   602B3400 c    9C0   3D8    3D   3D   OK
70010  08 F6   01   714E7 - 72BBD   383A4A00 c  1EA30 16D5C    95   95   OK
70012  09 3B   01   72BBD - 74E48   38008230 c  2F44C 228B0    85   85   OK
78000  5A 40   04   78014 - 781ED      4B688     1D94  1D94   000BAF5B unknown CRC
78002  01 11   11   781ED - 785F7   30080000 c   5500  40A4    69   69   OK
78004  02 58   0C   785F7 - 78634   24000000      3C8   3C8    05   05   OK
78006  03 01   40   78634 - 78BFA   FFE00200     5C64  5C64    19   19   OK
78008  04 31   01   78BFA - 7920F          0 c   7C40  6148    49   49   OK
7800A  05 9E   01   7920F - 79251       DFB0 c    4EC   424    F3   F3   OK
7800C  06 94   03   79251 - 794AA      402E0 c   3020  258C    44   44   OK
7800E  07 ED   03   794AA - 794E7   602B3400 c    9C0   3D8    3D   3D   OK
78010  08 F6   01   794E7 - 7ABBD   383A4A00 c  1EA30 16D5C    95   95   OK
78012  09 3B   01   7ABBD - 7CE48   38008230 c  2F44C 228B0    85   85   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
ROYL directory module 0x000B found at 0x7F19A
Active directory flag = 0x00
Identifying SA regions ...
Reg#  Reg size    Reg loc
0x00  0x000C6A5C  0x00000000
0x01  0x000C6A5C  0x00191400
Verifying ROYL modules ...
ID          Size (bytes)         Address    Checksum
dir   hdr    dir       hdr
0001  N/A    00008000  N/A        000C591D             N/A
000A  OK     0000004E  00000200   0007C000   00000000  OK
000B  OK     00000129  00000200   0007F19A   00000000  OK
020B  OK     00000129  00000200   0007D19A   00000000  OK
0181  OK     00000C00  OK         0007B400   00000000  OK
0030  OK     00000400  OK         0007B000   00000000  OK
0047  OK     00000B18  00180000   0007C682   00000000  OK
000D  OK     00000108  00000200   0007C04E   00000000  OK
004F  OK     0000052C  00000600   0007C156   00000000  OK
ROYL directory module 0x020B found at 0x7D19A
Active directory flag = 0x02
dir   hdr    dir       hdr
dir  -  Module ID/Size as reported in directory module (0x20B or 0x0B)
hdr  -  Module ID/Size as reported in module's header
N/A  -  Not Applicable
BAD  -  Module has invalid checksum. This may be due to non-existent module.
ROM modules saved to Flash_00\000Bmods and Flash_00\020Bmods
Active directory is 0x20B
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 10/10
Head map #1 = 0x03FF / 0b0000001111111111
Head map #2 = 0x03FF / 0b0000001111111111
DCM = | W | 2 J 6 C H 2 C
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : bottom VCM
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Analysing active 0x0D module ...
Firmware Version = 01.01A01
World Wide Name = 50014EE0047EA948
Model Number = WDC WD40NMZW-11GX6S1
Serial Number =
Analysing active 0x4F module ...
ROM version = 0002001P
Analysing active 0x47 module ...
Preamp values
0  012E0581
1  012C057A
2  0130057E
3  01320377
4  01300481
5  022E057E
6  01300581
7  012E0473
8  002C0681
9  01280573
Microjogs
0  0000
1  0000
2  0000
3  0000
4  0000
5  0000
6  0000
7  0000
8  0000
9  0000
Head/Media DCM = 6J
I think ROM is OK ...
And why when i put the rom chip on sata donor pcb i have this problem ? It's my mistake ?
PostPosted: January 22nd, 2019, 15:50
In my experience with Spyglass drives (have done quite a few), a spin up and immediate spin down has been heads every time. Usually with at least one dirty head, indicating MD.
PostPosted: January 22nd, 2019, 16:30
the problem is that not having a pcb to be able to connect I can not understand the problem, I tried to use the wd usb adapter of mrt using the cables I connected e71 etc. but I had no results, I also eliminated the capacitors on I went out and the sata port was connected to me once but without transmitting anything. They are therefore looking for a pcb to be able to at least make the diagnosis to the customer
PostPosted: January 22nd, 2019, 19:00
-:) I'm not use this method, I think it's important to make a right diagnosis for any customer, it's my deformation - :) I have a cleaning room and I make regular head swap but this disk it's new for me. Thanks for support, I search a 002 pcb and make a regular diagnostic. Thanks friend
PostPosted: January 23rd, 2019, 2:14
+1 "it's important to make a right diagnosis" that why you should not power on this drive before a checking heads.
Right now you are risking customers data. As pcimage stated "Usually with at least one dirty head, indicating MD."
My advise would be: Get a donor drive, take heads out and put them back a couple of times. If donor is still working then go back to your cleaning room and check patients heads under your microscope.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 23rd, 2019, 3:38
Unfortunately it seems he wants to “diagnose it to death” :-(
@magnetepazzo ... Please accept the advice you’ve been given and at least examine the heads from patient microscopically, for the sake of your client.
PostPosted: January 23rd, 2019, 5:16
Why do you affirm this? I have explained well that the heads do not move and do not click and as soon as the disk is also powered with the pcb usb, start but stops immediately, does not even reach the speed of release of the heads so why say this? I do not want to kill the disk and I want to offer the best solution for my client, since this flaw is atypical in my opinion, I think at least you need to connect to see some logs, otherwise it would be absurd to think of replacing the heads without even understanding the reason immediate stop, I do not think the doctor works a patient without first having done the preparatory exams.
PostPosted: January 23rd, 2019, 16:31
Can you upload the donor and client's ROM?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 48 guests
